Question about Belkin (F5D7050) 802.11a/g/b Wireless Adapter
Wep key to connect xbox
I need to connoct a x box 360 to my bilkin 54gG but i need the wep key to do ,how can i locate this
  • Anonymous Dec 13, 2008
    i want to connect my xboxlive to the wierless abapter next boor but i dont have the wep code how do i get it
  • 1,183 Answers
WEP key is the security key you had set when you had set up the network. You need to access the wireless router page
1.Click start >Run>type cmd >hit enter
A black command prompt window comes up
2.Type Ipconfig and hit enter
3. Note down the Ip address next to default gateway that is usually 198.168.1.1
4. Open internet explorer , in the address bar type the default gatway (198.168.1.1)
5 Hit go
6. The belkin password screen would pop up,
7. enter the default user name and password
8. go to the wirless page and check the WEP key
If you donot know the default admin and password , its time to call belkin and they would let you know how to get into the router to check the WEP key
1 800 2BELKIN x2263
Posted on Apr 06, 2008
I just got this new x box 360 to replace the older version x box, but i am not able to connect to x box live, the wep key is correct, but it still says there is a problem and it will not connect. I have...
Likely is not an issue with your Xbox 360 but instead an issue with your router being able to communicate with the Xbox 360. I had a similar issue. (eventually I was not able to use a wep key as my router was not syncing up with any of my devices proeperly with the wep key. I factory reset my router and instead closed my router to allow only specific mac ids to allow access instead of using the wep function)
If you are in control of your router then attempt (for testing only) to open your router so that it does not require a security wep code. If you are able to connect your Xbox 360 via this route then you know that it is an issue with the router trying to communicate via wep key use.
Also, try connecting via lan line and making sure that your router is able to work with your Xbox 360. Eliminate all scenarios before you take back your Xbox 360 or any other device when dealing with routers. Likely culprit is not the device but the way the router is trying to communicate with the device.
Jul 18, 2011 | Video Game Consoles & Games
It will not connect to xbox live . it keep saying enter the wep key for this network
you need the password for the wireless you are connecting to, unless you provide that password (wep key) you will not be able to connect to that router. make sure you are connecting to your own router and provide the right password (wep key)
Mar 23, 2011 | Microsoft Xbox 360 Console
I cant find the wap key to connect to xbox live i ahve a sky wireless router help!!!!
Greetings Joecosens,
Fortunately, the WEP key can be located on the bottom, or backside of the router. If you have changed your router from factory settings, your WEP key is whatever you have changed it to. But if you have not changed it, then it should be on your router. The WEP key is a combination of letters and numbers. If further assistance is needed, please contact me directly. Thank you for using FIxYa! =) Please rate. Kindest regards.
Nov 13, 2010 | Microsoft Xbox 360 Console
How do i find out my wpa/ wep key for my xbox 360 to configure the wireless connection ?
The WEP/WPA encryption key is configured in the wireless settings of the wireless router. Go into your router's wireless settings to get this encryption key and the SSID, note these settings you need to configure the Xbox 360 with these settings.
For instructions on configuring the Xbox, please click on this link and follow the instructions :-
http://fixhomenetwork.com/xbox-play-station-wii.php
Jul 10, 2010 | Computers & Internet
What does wep64 key mean and what do i need to do fot the xbox 360 live connection
WEP Wired equivalent privacy is supposed to give the same security as a wired network in a wireless network. 64 means a 64 bit key is required to get the thing working. Look on the bottom of your wireless adaptor for the key it will be in the format xxxx xxxx xxxx xxxx. type it in carefully when requested.
Feb 08, 2010 | Microsoft Wireless Network Adapter Xbox...
What is a wep key, and where will i find it, for setting up xbox 360 thanks
WEP stands for Wireless Encryption Protocol and it is the wireless key for your router.
The length of a WEP key depends on the type of WEP security (called "encryption") utilized:
  • 40- / 64-bit WEP: 10 digit key
  • 104- / 128-bit WEP: 26 digit key
  • 256-bit WEP: 58 digit key
You will need to find the WEP key in your router's administration page and then enter it on your xbox under the system settings then network settings.
Dec 25, 2009 | Video Game Consoles & Games
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I got a new xbox 360, and i need to connect my xbox back
you need to go to your xbox settings and your network settings, find your network and put in the wep key for your router. If you don't know your wep key for your router, the easiest way to find it is to go on your computer, open a browser of some kind (e.g. internet explorer, firefox, safari etc.) and type in the ip address. The most standard ip address is 192.168.1.1 or something close to that. It should bring up the settings for your router and you can find the wep key usually under the wireless tab and then wireless security and your wep key should be right there! enter it into your xbox and have fun gaming. =)
Jun 16, 2009 | Microsoft Wireless Network Adapter Xbox...
Don't know wep key to hook up xbox 360
Hi, We've had our x-box since April and we just plugged into the back or our Belkin router and have connection. I've never heard of wep 64 or wep 128 Key
Feb 08, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7050) 802.11a/g/b Wireless Adapter Logo
381 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
