Question about E-Machines eMachines Desktop PC
Processor? I have a T2792 emachine. The machine will shut down right in the middle of doing something, but doesn't power all the way off. The green power button turns a solid yellow and stays on along with the hard drive light and disk drive light. All the fans stay running. It's like it goes into hybernation, but the only way to get it back on is to hold in the power button, turn it off, and power back up. I'm running 1.5G ram and a 500W power supply. Any Idea's? Michael
  • MLawler1031 Apr 09, 2008
    E machine model W3506:
    I don't remember the exact symptoms the first time I started having problems because it was several months ago and I didn't have the money to replace the power supply at that time. At that time things started to go bad, like the disc would stop working then the monitor would go blank and finally it wouldn't boot at all.
    I replaced the power supply and cleaned the machine last week and things worked fine.
    Yesterday the machine shut itself down. I rebooted and it worked fine.
    Today it went down and I rebooted. It came up and ran about 15 minutes before it shut down. I rebooted and it worked about three minutes. I turned the power off for several hours and then turned it on and it came up for about three minutes before shutting itself down.
    To me its acting like an overheating problem.
    Is there a component or a virus that would cause this or do I have another bad power supply?
    MLawler1031@Netscape.Net
  • Dwayne Stewart May 11, 2010
    It's possible to be a power supply problem. These are frequent. Restarts and shutdowns may be a sign of this. If you say your computer goes into "hibernate" mode instead, it may be software related. Do you have any virus protection on that computer?
    Master:
    Sergeant:
  • 482 Answers
The power box is going bad. It's a matter of time before it will not turn back on. you will see. i would get a new one from ebay and replace it.
Posted on Apr 07, 2008
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
I WANT TO RESTORE MY FACTORY SETTINGS BUT I DON'T HAVE THE CD
I researched your question for you. The disks are avaliable but there is a cost to replace them. Click on this link or copy and paste the link into your web browser so it takes you there, here is the link.
http://recovery-disks.com/emachines/emachines-desktop/emachines-desktop-t-series-t2792.html
I hope this helps you out, if it does please click Yes on the web page you are reading this email on. Thank you.
Apr 05, 2011 | E-Machines T2792 PC Desktop
I have an e-machine T2792. It boots up fine then runs for 10 to 20 min. then shuts down. Could this be my cpu going bad? Thank You Scott
CPU, the motherboard and the rest of the chips in it is subject to wear and tear. This is in addition to the high temperature it is operating with. The sudden shut down is cause by a failure of one component (usually the Processor) who's burned out.
Sep 12, 2010 | E-Machines eMachines Desktop PC
I need help restoring my emachine t2792 to factore default settings
Go to start menu -> Click on all programs -> click on Emachine ->click on Emachine recovery management -> Click on restore on the bar across the top ->click on restore to system factory default. This will take some time and reset your Computer to factory default. Note:- This will erase all your data also so create backup if anything important is there before you reset to default. If this process doesn't work for you or you dont find the option then Use the disk bundled with PC to restore/reinstall Windows.
May 24, 2010 | E-Machines T2792 PC Desktop
PC SHUT down
three things i find to cause this,
one, the power supply is bad,
two, the power connector is lose or not push in
three, the heat sink on the processor has come off. This will cause the cpu to over heat and self shut off.
to test the power supply, pull the connector off the mother board and short the green wire to any black wire with a paper clip, this will switch on the power and see if it stays on.
if you need to replace it, you cannot use a regular atx power supply. E machines have a different pin out.
Aug 12, 2009 | Dell E151FPp 15" Flat Panel LCD Monitor
E-Machines T2792 (Windoes XP Home) Shuts down occasionally. I just want to reformat my hard drive and start fresh, but do not have the OS Reinstallation disks and e-Machines doesn't have them any more....
Check your program list and see if there is an emachines backup or restore CD creation application. Most recent computers did not come with disks. Instead, the user needs t create their own. If you've never created a set, you might be in luck. Directions should be on their website.
Aug 05, 2009 | E-Machines T2792 PC Desktop
EMachines t3626 shuts down at random
You may be dealing with bad or overheating with your processor or memory. If possible, try swapping out your memory chips to see if that does the trick. If not, you will have to try swapping out the processor (much less likely you'll be able to swing that).
Jul 28, 2009 | E-Machines eMachines Desktop PC
Hardware stops
mite try www.tigerdirect.com or www.directron.com the will suggest a compatable board for you lala linda.
May 31, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Shut down
Check to make sure you're not going into Stand-By mode. Click on the Start Menu....Shut Down and make sure you're not clicking on Standby.
Feb 23, 2008 | E-Machines eMachines Desktop PC
Hard drive light stays on and system freezes
You may have a hardware problem of some sort. The first place I'd start is to check the power supply voltages. If one or more voltages is off tolerance, this will cause all sorts of symptoms. if you have a voltmeter check especially the +5, +3.3, +12, & +5 standby voltages. Use this site as a reference http://pinouts.ru/Power/atx_v2_pinout.shtml If the supply checks out faulty, buy a replacement, or, if tech savvy, you might repair it-- probable component defects= one or more electrolytic capacitors. Other possible problems are Memory errors (try subbing a RAM stick), hard drive developing errors, or a bad chip on the motherboard. If you have some spare parts, RAM, hard disk, you can try subbing parts and narrow down the problem.
Apr 27, 2007 | E-Machines T2792 PC Desktop
E-Machines eMachines Desktop PC Logo
124 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
