Question about Dishwashers
I have a Maytag QuietSeries 300 dishwasher. My original problem was with the control panel lights not coming on. Another repair website recommended replacing the circuit board. We replaced the board, but it did not solve the problem & the dishwasher would not work. Replaced the control panel. Lights come on, but when the start button is pushed "21" flashes on the time display. What do I do?
  • 1 more comment
  • watkinsinaz Apr 04, 2008
    I followed the procedure you described in your solution. The plastic retainer clip was never removed from the circuit board. I rechecked my connection from the conductor strip to the circuit board. The conductor strip is fully inserted, the retainer clip fully pushed back. I still receive the same error code: 21. Any other solutions?
    I followed the link you gave & read through the posts @ that site. In your link it refers to replacing the membrane, with a link for a control panel. I've already replaced the control panel. Any other help you can give me?
  • Anonymous Mar 21, 2014
    It is a DWL7075DWW or ...DBBB or ...MBSS. The control panel buttons will not light up or work.
    Genius:
  • 3,422 Answers
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 04, 2008
  • 4 more comments
  • Priya darshan Apr 04, 2008
    Ok here is a solution to your problem.
    There is a particular procedure to plugging the conductor strip (coming
    from the panel) into the circuit board. The correct method is to place
    the plastic retainer clip on the circuit board connector first (if you
    have removed it). Pull the retainer out slightly and insert the flat
    conductor strip into it.
    Then push the retainer in to lock the conductor strip in place.
    PS. The mistake that you might have made was to remove the plastic retainer clip and
    place it on the conductor. Then push the conductor strip into the
    connector and slid the retainer down the conductor strip and onto the
    connector. THIS DOES NOT GIVE A TIGHT CONNECTION and if the machine
    works at all it is only because of luck.
    Check his forum out.Click HERE
    Regarding the refund you can send an email to premium.support@fixya.com
    Hope your problem gets solved soon..
    Goodluck..
    I am sorry please ignore my last post it was not for you.
    I will be posting more solutions.
  • Priya darshan Apr 05, 2008
    Well .those were only the possible solutions which i gave you to fix the problem.I think you will have to call a tech to fix this problem.If i find any solution i will definetly post it here.
    Goodluck,
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
Wont drain
most have a valve that is operated by a solenoid valve, possible that wires have come off, or valve is stuck shut
Jan 22, 2015 | Maytag QuietSeries 300 Dishwasher...
Control Panel Problem on a Maytag DW MDBTT79AWW
I had this same problem, ordered the replacement control panel from whirlpool. The new panel worked for two weeks, then stopped working again. OUCH!
The replacement part costs $264.34 and has no warranty if you do it yourself.
I think I am now going shopping for something other than a Whirlpool or Maytag machine. They have terrible customer service.
Feb 12, 2010 | Maytag Dishwashers
Quietseries 300 : Fills OK, timer functions OK, no water movement
Check the Lid switch. Most top load machines will not spin unless the lid is down and this is determined by the lid switch.
Jan 07, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag quietseries 300 dishwasher not cleaning properly
UNGLOGGED THE BOTTOM/TOP . CLEAN IT AND SHOULD BE OKAYARMS SPRAYER, THEN IF IS GOOD AN NOT ENOUGH WATER CHECK WATER VALE SCREEN
Aug 19, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Dishwashers Logo
316 people viewed this question
Top Dishwashers Experts
