I have a PIXMA ip3000 Canon printer.I have had it 2 years with no problems.When I try to print something I gat a reading "paper Thickness lever position.I have no= idea what that means.I was going to re install my startup disc but am unable to locate it.Could you please send me a new one?Thjank You,Donald E. Wilson [email protected]
  • pazz11 Nov 11, 2008
    paper thickness lever position comes up then says printer off line which it is not
The problem was resolved by the first contact.I downloaded the startup program and everything worked out great. donewil
Posted on Apr 05, 2008
SOURCE:
Im trying to print with our Canon PIXMA IP3000 printer but it doesn't allow printing with a message box appearing "printer is offline" but the printer is perfectly fine and plugged in. Then I chec
check to make sure you have it set on the right printer by find printer... if that is okay check your ink levels and make sure they are in properly... you might also want to try restarting the printer and if none of those work you will have to try and uninstall the printer and then reinstall it....
Dec 21, 2012 | Canon PIXMA iP3000 InkJet Photo Printer
I have a Canon Pixma MP 130/110 Printer. Machine is not printing. Have been through all the recommended cleaning/ maintenance procedures several times and fitted new ink cartridges all to no avail. Message...
Pixma IP3000
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Mar 06, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I have Canon pixma MX310 and I just trying to set it up.I'm trying to print and there is message open paper out tray.What is that mean and how I can fix it
The printer will not print as long as the paper output tray is closed.
  1. Open the Paper Output Tray (2).
    Put your finger in the rounded indent beside the Paper Output Tray and open it gently.
  2. Open the Output Tray Extension (3).
    Open up and set the Output Tray Extension completely by pressing down the hollow on its front side.
  3. Adjust the position of the Paper Thickness Lever (4).
    Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper.
Oct 29, 2010 | Canon PIXMA MX310 All-In-One Printer
My canon inkjet pixma ip3000 says it has no paper when it has. It has worked before but now it just says paper out when i try to print.
this i think is simple. you put the paper on wrong. it sometimes happens to me on me printer. look at your operating manuel to see how to properly put on the paper
Oct 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer does not print documents. Model IP3000 pixma. Approx 3 years old, used in my classroom. Printer has been working well until this morning. This is a sudden failure. Performed all maintainence with...
I had this very same ongoing problem with my iP3000 and recently with my iX4000 but I refused to believe it was the printheads as the iP3000 would print cd/dvd discs without a problem. Colour on paper was always there even though I used Calidad tanks.
My solution, or more aptly, my workaround was to change the paper setting from Plain paper to Glossy paper but still using plain paper and low and behold, after nine months of test pages with only the Windows logo it stated printing black text again albeit slowly now. Same deal for the iX4000, it started printing black text on plain paper as well after 4 weeks when the problem first occurred
I also did all the maintenance rigmarole over and over etc...with no results. My printers are hooked up to two PC's, Vista and XP so maybe I eventually scrambled the printers barins or something, anyway I'm printing again.
Worth a try and nothing to lose
Sep 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Recurent paper jam on Cannon Pixma MX300
Some printers have a certain paper height or paper load you can have loaded at one time. I would try loading a smaller amount of paper and see if that helps. If it still does the same thing your paper thickness lever may be damaged.
Sep 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Ink smudge on envelope
dvlknc
The paper thickness lever is not on the front...it is on the floor of the "paper output tray" chamber. It is hard to see without directed light.
Refer to Loading Paper section of the Quick Start Guide....p 15 2 Prepare to load paper
(4) Adjust Paper Thickness Lever
(See diagram)
Or look at the "User's Guide on-screen manual" as directed by the Note on p. 17
I really had to search to find this lever while attempting to resolve my problem with a badly aligned printing head. I am going to have to buy a new printer. It definitely won't be a Canon due to the rip off cost of print cartridges.
Hope this is helpful.
kellyplus
Nov 14, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon pixma mp460
check for obstruction and paper thickness lever on the printer and try printing again.
Apr 14, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Open Questions:
112 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
