Question about RCA P52771AT 52" Rear Projection Television
Blue Halo and too much blue...
RCA P52771AT with PTK178LB chassis:I have a blue halo and from what I've read, it sounds like I need to replace the convergence ICs. Can someone help me identify these chips or circuit board? where can I get the parts?
Thanks,
Arby
  • randykbell Apr 05, 2008
    did the coolant before my post. I've since been told this model does
    not have IC, but a circuit board. any info on the board will be
    helpful...
    the picture attached doesn't really show the effect, but the whole
    screen has a blue hue and the left side of her face the blue halo.
    thanks in advance...
  • RCA Master
  • 8,617 Answers
If its a halo such as a glo you need coolant change in the CRT, if its like a 3D effect then you need new Convergence ICs. Can you post a picyure of your screen and I will properly diagnose it for you then be better equiped to help you properly.
Posted on Apr 04, 2008
  • Sonny Berry
    Sonny Berry Apr 05, 2008
    yes your model has ICs not the conventional type as used in other TVs. However they are difficult to change. I am trying to find a source for that module. Through Thomson/RCA its most likely no longer available . I will repost as soon as I find some info on the module.
SOURCE:
I see a halo of red green and blue
Possibility is the geometric correction drive IC / convergence IC, need replacing. Another possibility is the bulb is reaching end of life.
Jan 15, 2011 | RCA P52920BL 52" Rear Projection...
Halo around blue, extremely bad when watching
The CRT coolant in the Blue CRT needs replacement. The green will soon follow. Very common problem with phillips. You can get the phillips CRT coolant kit from www.tvrepairworld.com which contains the coolant and the CD with instructions.
May 10, 2010 | Philips 60PP9363 60" Rear Projection...
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
Aug 04, 2009 | RCA P52771AT 52" Rear Projection...
Blue halo on bottom 1/3 - Convergence issue with my 43HX70
HELLO SOUND LIKE YOU NEED TO CHANGE YOU IC CHIP'S ON THE CONVERGENCE BOARD.1!1 THERE WILL BE THREE OF THEM .!!! CHANGE ALL OF THEM AND THIS SHOULD FIX YOUR SET. "GOOD LUCK"
Aug 13, 2008 | Toshiba 43HX70 43" Rear Projection...
Rca p52771at
Sounds like you have a bad screen asy,check around the pots to see if cracks are present,part number for this item is 204809,must use the generic,the part is no longer available from Thomson.
Feb 05, 2008 | RCA P52771AT 52" Rear Projection...
Rca p52754at projection tv
A halo as youre refering to usually means your coolant in the effected tube needs replacing. Can be purchased at http://electronix.com/ . Let me know if I can be of any further assistance.
Jan 03, 2008 | RCA HD52W59 HDTV Projection Television
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Blue shadow RCA p52771at
hi yeh it does sound right sorry do know anybody arround there... good luck
Feb 22, 2006 | RCA P52771AT 52" Rear Projection...
Televison & Video Logo
190 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
