Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE XL44 Self-Cleaning Gas Range Model No. JGBP79
My range is at least 10 years old, and does not have touch pad numbers, so I can't perform the FIX you suggested. Is there a way to adjust the temperature of this range, similar to the one you describe for the touch pad model?
Thanks,
Marv Shuck - Fallbrook, CA
SOURCE: JGBP79 GE Spectra XL44
Yes I had the same problem on my JGBBP79. Change the lower igniter. About $75. Keep the range for a few more years and get rid of it. The next problem you'll mostly likely have is the touch pad F1 error. That stupid thing is +$300 and nothing more than a membrane touch pad attached to some glass. :-(
Posted on Nov 19, 2007
SOURCE: Can't Get My GE Profile XL44 Self-Cleaning Gas Range to CLEAN ! ! ! ! !
I also have a XL44 (GE JGBP90) and I can't figure out how to latch the door. When I press Self Clean, the display asks me to latch the door, but I don't see a lever. I think it might involve lifting the range, but I don't want to force it. Any ideas?
Posted on Mar 10, 2008
SOURCE: Low Heat from GE XL44 gas range
you can increase the sides of the flames by opening the orifices, if not differences. make the orifices holes a bit bigger, you can have as big of a flame as you want. those orifices are at the connection of the burner with the valve that supplies gas to the burners.
Posted on Dec 09, 2008
  • 126 Answers
SOURCE: Bake mode will not work
Is the bake igniter working ? There are two igniters one for bake and one for broil My guess is that the bake igniter is bad and only the broil igniter is working. part #WB2X9154.
Posted on Jan 16, 2009
zabolyx
  • 38 Answers
SOURCE: GE XL44 Broiler/Self Clean Trips GFI
This should be a 220 volt appliance so I'm trying to figure how this was connected to a GFI. Does it have a second connection to power the controls?
Most GFI uints I have seen are not rated for large amounts of power consumption. I used to throw the one in my bathroom if I was running the electric heater and the wife fired up the hair dryer.
I'm wondering if this indeed does require the additional 110 connection then it sould be pulling heavy current from it to aid in the cleaning process. I've never seen a stove that needed the extra. My old electric range had only the 220 as well as my elders.
So if that is the case then you should not be running that through the GFI outlet because of the heavy drain will heat the breaker in the GFI and cause it to trip. Breakers actually work very similar to how the old fuses work. Heat causes the switch to throw. GFI units have a lower tolerance (designed to detect shorts quicker to save your life) and trip quicker than breakers do.
Posted on Apr 02, 2009
My GE XL44 Self-Cleaning Gas oven heats up but is about 125-130 degrees cooler than what it is set for.
To Adjust the Thermostat
  1. Touch the BROIL HI/LO and BAKE pads at the same time for 3 seconds until the display shows SF.
  2. Touch the BAKE pad. A two digit number shows in the display.
  3. Touch BAKE again to alternate between increasing and decreasing the oven temperature.
  4. The oven temperature can be adjusted up to (+) 35°F (19°C) hotter or (-) 35°F (19°C) cooler. Touch the number pads the same way you read them. For example, to change the oven temperature 15°F (8°C), touch 1 and 5.
  5. When you have made the adjustment, touch the START pad to go back to the time of day display. Use your oven as you would normally.
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Fi keeps beeping yet control still operates everything normally on my ge xl44 gas range model JGBP26GEN..it started last nite. Ive tried resetting the circuit breaker and pressing the keys in many...
The F1 code can be 1 of 2 things. Try disconnecting the ribbon cable from the touch pad to the clock. Then reconnect power and if the code comes back with 32 seconds the eoc is bad. If it doesn't the touch pad is bad.
Jun 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
F-1 error code on model jgbp79wew1ww
Hi There
Hi how are you today? I'm sending you this and i hope this helps you let me know. F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad Thank you for writing to fix ya.
Best regards Richard and merry xmas and a happy new year
Dec 11, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
I have GE XL44 range. How long should i run self
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Jan 10, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Jan 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
XL44 Self Cleaning Gas Range
your set up foir the wrong type of gas
you probaly have a natural gas oven
'and your using propane
Dec 16, 2007 | GE JGBP24 Gas Kitchen Range
Nov 08, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
