Question about Olympus FE-190 Digital Camera
Can't take pictures.
When I turn my camera on, the less goes back and forth for a few secords until it seems it is ready to take the picture. But then image to be pictured is zoomed, fuzzy and won't display to take picture. Then when I press the shoot button sometimes it takes the picture and sometimes it doesn't. But regardless the pictures look very fuzzy and aweful. It was taking great pictures yesterday.
Your help will be appreciated! Regards.
  • 477 Answers
Try zooming in on a object and see it it get clearer. the problem is your zoom lens motor is stuck or malfunctioning. This is a very common problem with digital cameras. sometimes you can take compressed air and blow around the lens and clear the blockage or lightly tap the camera lens down with it off to free up the focus gear. if it does now work it then needs tobe serviced or repaired. I had the same model last week for the same problem. That lens had tobe replaced. but try that first and see if it helps.
Posted on Apr 04, 2008
SOURCE:
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
On my 36in sony the picture goes in and out..from picture to black back and forth constiantly..im just clue less
a picture that blinks in & out every few seconds then it could be a bad tube.
I know the older models the picture would flash in and out with snow etc. that was a tuner problem.
haven't worked on very many sony wega's, maybe another tech here has a better ans.
Mar 08, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lens error!!!!
when i turn on my camera the lens comes out ,then goes back in saying theres a lens error.it tells me to restart my camera but im not sure how too. is it just turning it back on ,or is there a reset button?
Jul 03, 2008 | Canon PowerShot S5 IS Digital Camera
Canon Powershot A520 Stuck in View Picture Mode
You need to power it with rechargable batteries. with the MAH being no less than 2000. I bought a charger which came with 2batteries for less than a tenner
Sep 30, 2007 | Canon PowerShot A520 Digital Camera
Monitor goes black
It always does that while it's powering up the flash again. If you're saying it doesn't come back after a few more seconds, that is a problem. Or maybe by that time, the power saver kicks in. You can tell if the power light starts blinking. Then you just have to press the shutter button again to turn it back on.
Aug 20, 2007 | Nikon COOLPIX L5 Digital Camera
Olympus FE-190 Digital Camera Logo
90 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
