Question about NEC PlasmaSync 42VP4D 42 in. HD-Ready Television
Where to buy pnt-426 or 3s110101
Where to buy power supply pnt-426 or 3s110101 for px-42vp4d fbpnew@gmail.com
  • Cosmologist May 13, 2008
    On-screen menu works fine. Power supply shuts down (loud clik from power supply relay?) when I connect video input. I assume full video increases load on power supply.
  • paul hughes Jan 29, 2009
    need to get power supply working tv switches on clicks and goes to standby
    any repair kits avalible
I had same problem.
Also check all 4.7 Ohm resistors for o/c R307/308/309/310 5Watt W/W.
Posted on Nov 25, 2008
Have got same problem
check solder on chip resistor and transistor near c254
change capacitor power c254 200v 1500µF
Posted on May 17, 2008
  • 4 Answers
Union electronis or vance baldwin
Posted on Apr 26, 2008
Metade tela preta metade branca desliga com sinal de video sem sinal comtinua ligada -nec px-42vm5a
Hello
From your description, I can't understand the problem of your TV well. "Half white half black screen with video signals"; you describes what? Please give me more details about the fault, as clear as you can, so that I can help you. Send these details to me by Fixya. OK.
May 16, 2011 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Power is on--for my PX-E869U turntable but the motor pully that the belt wraps around does nut spin. I would guess the the motor is at fault. How much work is it too replace and where could I find a part#...
To test the motor just disconect the leads to it from the power supply. As these motors are normally under 12 volts connect a PP9 battery to it. It should spin. If it doesn't it's gone! If it does then the motor isn't getting any juice from the power supply.
Mar 04, 2011 | Aiwa PX-E860 Turntable
I need a motor for my aiwa px-e 860 turntable
Hi, stylus city can supply a motor for this turntable. Styluscity@gmail.com
Jun 23, 2010 | Aiwa PX-E860 Turntable
Does anyone have the voltage specs on a PNT-426 Power Supply. It is for my NEC PlasmaSync PX-42VM5A Monitor. My electrician has found a faulty diode but doesn't have the voltage specs on it. I have a...
I have a PX-42VM5A and my Power supply is a PNT-426 (by Sanken Electric Co. LDT). Here are my specs: INPUT: AC 100-240V; OUTPUT: (there are nine outputs) +170v 1.6A; +60v 1.6A; +5v 4.0A; +2.5v 1.9A; +3.5v 1.9A; +7v 1.0A; +12v 0.5A; +12 v 1.9A and +6v 1.2A
Jun 17, 2009 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
NEC PX-42VP4G Power supply
Check to be sure that there is no voltage on the input line. You don't indicate what input you are using. Since the set appears to work without an input connected, try looking at the input cable. Also, if the problem is internal to the set, shorting the input jack would cause the same behavior. Please update this with what you find.
Dan
May 13, 2008 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Nec px 42vp5
The fault is on the PSU board.
Replace D 28 on the PSU board. You have to use a fast diode (I used BYW 95). Replace also the
330 uF/35V and the 22uF/50V near to this diode.
After this the unit will work perfect.
Oct 25, 2007 | Televison & Video
42VP4D
Try to call the Company Tech Support and ask the part. Thats the perfect place to get your perfect parts. Or get your part number and search the web for inexpensive one but make sure you get the right one. Good luck
Aug 13, 2007 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
NEC PlasmaSync 42VP4D 42 in. HD-Ready Television Logo
929 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
