Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Sylvia not heating at all
Laurden on Apr 04, 2008
made coffee this a.m.; not a problem until ready to froth -- no steam. checked online, found out about resetting thermostat, red button was in, when pushed wouldn't go in any further and when pulled out stayed out (no tension); after trying to reset, tried to use, no heat at all.
If replacement parts are needed, where do we get them? estimate cost?
Comments:
Apr 04, 2008
- neither site listed any parts for the rancilio; other response said the cost of parts would exceed cost of new machine (that would be over $500?????
Apr 04, 2008
- on troubleshooting page there is a person who asked about replacing thermostat; we found on another site (which you did not recommend for parts -- you recommended Sears which doesn't carry)a thermostat for the silvia costs $14.95. Why do you say it would cost more to replace the machine than to replace the thermostat? Is there something else wrong besides the thermostat? Thanks
Apr 04, 2008
- what other things?
Apr 04, 2008
- I ended up calling a rancilio repair company who said they thought it was probably the safety thermostat and recommended that I also replace the other 2 thermostats since the machine is 5 years old -- cost for all parts which are easily done at home was $50 with shipping. I told them your comment that I scrap the machine because it would cost over $500 -- they said that the worst case scenario would be the heating element. If the thermostats don't do it then I could send them the machine and they would give me an estimate -- if they had to replace the heating element it would cost about $125 plus shipping. I am going with their advice and must say I was disappointed with yours --just a note--there is no "whole board" in an espresso machine: I grant you must know lots about computers, but not about espresso machines. I would like to hold you to your guarantee and have my $10 refund.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 04, 2008
Not Rated)
coolguy008
Rank: Wiz
Rating: 84%, 1263 votes
I believe the problem is with the thermostat.You will have to replace it.
Please check out this forum HERE
This will help you fix the problem.
If you need any parts you can get it from HERE or HERE
Goodluck,
Please don't forget to accept the solution as fixya..
Comments:
Apr 04, 2008
- I am sorry for that but it is true it will cost you more than the new machine.
I strongly suggest you to go for a new one.
Apr 04, 2008
- I said that because even after replacing the thermostat if you still face the problem then you will have to replace the other things which may cost more than that.
Apr 04, 2008
- What if the problem is with the whole board.Then you will have to replace it.
Apr 04, 2008
- Regarding the refund you can send an email to premium.support@fixya.com
Hope your problem gets solved soon..
Goodluck..
Was this helpful?
Yes
No
Solution #2
Not Rated)
osborne382
Rank: Wiz
Rating: 82%, 332 votes
replacement parts would exceed the value of the machine, I would purchase a new one and keep the old for parts
Was this helpful?
Yes
No
Related Problems
porta filter off pulled head screens off and still no water...
I have a quite old la pavoni p3v2 110v 2000w two group...
l am getting steam and l am getting hot water but no water...
Flow through head too fast. Coffee packed very tight and...
Can you Help with these Coffee and Espresso Maker problems?
Servicing New Zealand
Solve
I Live in the South Island of New Zealand and need to service my Rancilio Silvia coffe machine. Any... (More)
Water is not pumped enough, and...
Solve
Water is not pumped enough, and steam pressure is very low
The machine is only a couple months...
Solve
Machine is not dispensing coffee. If the portafilter is empty, hot water comes thru. But once it is... (More)
Model Epoca de2gr
Solve
We get a constantly water drain , it never stopes even we shut of the power .We do not have a manual... (More)
expresso maker cup stuck
Solve
I am house sitting at a place with a Ranchillo expresso maker.  After I tried to use it, I took... (More)
Sponsored Links
Describe your Appliance problem:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 724
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
(866) 895-9295
Rest assured, when you place an order for parts it...
Easy Appliance Parts
(800) 341-6361
Mr. Appliance Corporation is one of the largest...
Mr. Appliance
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
