Question about Xerox WorkCentre XD130DF Laser Printer
I need help with workcentre XD130df
How can i do to reset the error code J2. I press clear, auto, clear auto and numer 14 and start copy. but de error code dont´t finish, please help me
    President:
  • 2,072 Answers
J2 means the life of the drum has expired.
If replacing the drum does not fix it let me know.
J2 means the drum has met it's 18,000 page life.
Posted on Apr 06, 2008
SOURCE:
Error code H4
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Toshiba studo120 H4 error code
May 06, 2015 | Toshiba e-Studio 161 Copier Copier
Getting message H4
Jul 30, 2009 | Xerox WorkCentre XL2140df Laser Printer
I HAVE ERROR CODE H4
Give this a try, should resolve your code.
Aug 05, 2008 | Xerox WorkCentre XE80 Laser Printer
CODE U2
A U2 is related to a memory failure. May be a bad memory chip or main board. BUT, before we get drastic and move in that direction there are a couple of other things that I have seen cause that.
So, first I have seen the chip on the back of the drum cartridge cause that problem. You can try removing the drum cartridge and powering on the machine without that installed. See if it just comes up with a J2 code then. Or even a CH code. If the code changes you may simply have a failed drum cartridge.
Sometimes memory corruption can occur and you can clear it using this procedure..
Jul 23, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
XEROX WORKCENTRE XE80 DISPLAYS AN H3 CODE
Try this procedure.
Jul 17, 2008 | Xerox Office Equipment & Supplies
Model xd 130 df: I am getting error notices H and 4 and I can't figure out what they are and /or how to correct.
This should correct that.
> Support & Drivers > WorkCentre XD130df Digital Copier - Laser Printer Support > How To Clear an H4 Code Solution: Perform a Fault Reset 14 bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
Apr 18, 2008 | Office Equipment & Supplies
Error code 4H
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error 7 , the copier seems to be stuck
Give this a try, Just 7 is not normal. Is there a letter appearing first?
But try this procedure.
Apr 08, 2008 | Xerox WorkCentre XD130DF Laser Printer
SYSTEM ERROR H4-00
give this a try, Normally this helps.
Mar 10, 2008 | Toshiba e-Studio162D Copier
Sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
If this does not clear the problem the fuser will need replaced.
Feb 20, 2008 | Sharp AR-5316 Advanced Digital Imager...
Xerox WorkCentre XD130DF Laser Printer Logo
270 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
