Question about Dishwashers
Blanco Dishwasher BIDW605 does not
Blanco Dishwasher BIDW605 some times does not fill with water and on other occasions when it does fill fill water the wash pump only runs for about ten seconds and stops. Then after a few minutes L1 light flashes which indicates water fill problems. I do not have any wiring diagram for the unit or timing chart for the control board
  • 2 more comments
  • vern_cottee Apr 04, 2008
    Have checked all water filters and hoses and they are fine. The inlet water solenoid has been replaced but this did not fix the problem
  • Anonymous Mar 27, 2014
    blanco platinum dishwasher
    at 30 minutes wash time it stops at 18 minutes
  • Michael Dermitzakis
    Michael Dermitzakis Jun 22, 2015
    Did you find the solution to the issue you are having? I I'm having similar symptoms
    Sergeant:
    Champion:
  • 306 Answers
I would check the hose/water filters. make sure that you have proper flow from the hoses
Posted on Apr 04, 2008
SOURCE:
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
My dishwasher does not fill with water
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Feb 21, 2011 | Bosch SHU5315UC Dishwasher
Dishwasher not filling with water. Humming noise.
Hi
Daniel
Jan 08, 2011 | Bosch 24 in. SGS43C12 Classixx...
Will not fill with water
Hi
Daniel
Nov 27, 2010 | Zanussi ZT485 Built-in Dishwasher
Dishwasher is not filling up with water
Hi
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Oct 25, 2010 | Hotpoint Dishwashers
Dishwasher will not fill with water
Hi
Daniel
Oct 07, 2010 | Bosch Dishwashers
Not filling
Hi
When the Dishwasher is not filling in, you’ll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don’t get any value on the multimeter hen you'll need to replace the water inlet valve assembly.
Daniel
Aug 20, 2010 | Electrolux 23 in. ESL624 Built-in...
Dishwashers Logo
1,469 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
