Question about Reddy Heater-30-55,000 BTU Variable
Air screw setting
Does anyone know how many turns on the air screw on the reddy heater 55000 this screw is located on the back of the unit next to the air in take filter looks like a jet (no not a plain type jet) emial me at [email protected] Thanks
    Problem Solver:
  • 14 Answers
Remove plug on left and install low pressure air gauge. Adjust right screw to 3.4 psi on the gauge. See web site www.Desatech.com Manuals with parts breakdown are available on line.
Posted on May 29, 2008
SOURCE:
How do I keep the reddy heater 55000 btu working inside the house
Probably has an oxygen sensor so you don't run out of air. Probably not something i would bypass in a house.
Dec 12, 2014 | Reddy Heater-30-55,000 BTU Variable
Heater will not work even after switching all parts possible
Cannot answer well without specifics of what was changed. Did you blow the fuel lines clear with air pressure?
Jan 23, 2014 | Reddy Heating & Cooling
How to adjust carb. reddy heater 55000
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 03, 2011 | Reddy Heater-30-55,000 BTU Variable
Adjustments for reddy heater 55000 btu
heatman101
Jan 08, 2011 | Reddy Heater-30-55,000 BTU Variable
Will notdo anything power light is on reddy heater 55000 btu torpedo heater
Remove the top shell of the unit, see if the glow coil
tries to light up, if it doesnt you either have a bad outlet connection or the glow coil is broke
Feb 14, 2010 | Reddy R155D Utility Heater
55000 reddy heater unsteady flame
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 03, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
55000 reddyheater
What is the pressure setting on the air pump? The air pump delivers the fuel. the correct pump pressure deluvers the correct ampunt of fuel. Wrong amount of fuel/air ratio produces a stink!
Oct 30, 2008 | Reddy Heater-30-55,000 BTU Variable
Ready heater jet setting
Apr 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
304 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
T bone 1963
Superior Maintenance
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
