Question about Brother IntelliFAX 4100 Laser Fax
"Clacking sound when receiving faxes"
Theres a loud clacking sound when the fax receives documents, or when we make copies. The fax machine works fine otherwise, but the sound seems to be getting louder. Help!
  • Anonymous Apr 22, 2008
    Opened all accessable covers and cleaned everything then tried replacing the toner cartridge but still clicks loudly during warmup and receive.
  • Anonymous Mar 20, 2014
    Not sure why we hear dial up of phone number when faxing out. It still works but it never sounded like this
  • 82 Answers
A clacking noise is not good, what's the make and model of your machine.
Thank You,
Mikey
Posted on Apr 04, 2008
How do I fix the paper feed mechanism
Try to rep[lace the paper separation rubber.
May 21, 2014 | Brother IntelliFAX 2800 Laser Fax
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Black strip in documents when I send a fax
If you lift up the top, like you are clearing a jammed original, you should see a piece of glass across the machine. Look for something on the glass, usually white-out, and clean it. Test by making a copy. If copy is ok, then you fixed the problem.
Jul 12, 2010 | Brother IntelliFAX 4100 Laser Fax
Unable to fax
Please be specific!
Are the problem in document feeding section?
Are the problem that when you dial number you hear the clacking noise?
Are the error is LINE BUSY?
Or....?
Jun 21, 2010 | Canon L220 Plain Paper Laser Fax
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
Brother IntelliFAX 4100 Laser Fax Logo
170 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
