Question about Zanussi ZWD1470W Front Load Washer / Dryer
ZANUSSI ZWD1471S My zanussi zwd1471s filled then went immediately to rinse function,its now displaying error code E90
  • Anonymous Mar 22, 2014
    Aftner diamant. The washer because of screws in drum the display is showing E90
  • 35 Answers
An E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Posted on Apr 04, 2008
What does e90 mean?
  • E90 Error - YouTube
    • 3 MIN
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Zanussi jetsystem 1400- error e90
    e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
    Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    Hi zanussi fjr 1254 w error code e90 what does
    This error code seems to be the control board detecting a wrong configuration (in other words, an illogical set of sensing conditions, from its connected sensors and wiring). It apparently can happen, when wires become badly contacting, or if contaminated with motor brush carbon (the horrible black powder that comes off the motor commutator and brushes), or corroded from other contaminants from the soap dispenser area. You should be able to check this, remove, clean and replace the contacts:
    Jul 01, 2009 | Zanussi Washing Machines
    My zanussi will not turn on at all.
    If you give the facia a tap the display may come back on. You may then get an error code E90 being displayed. Either way you will require a new user interface pcb.
    Nov 18, 2008 | Zanussi FJS1225W Front Load Washer
    Zwd1471s washer dryer
    E20 code on Zanussi washer dryer ZWD1471
    washing machine working but dryer is not .
    Any advice please
    Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
    Zanussi washer/dryer zwd1471s
    E20 normally means there is a blockage in the drain tube/filter. I have the same problem, but the drain tube is clear. I have searched the web and found the solution being down to the "plastic bottle-like condensor having debris/fluff in it".
    Nov 30, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
    Zanussi washing machine
    E90 is not a listed error code however most 90 range codes relate to a faulty pcb, some times worn motor brushes and blocked filter and air traps can cause some innacurate error codes being displayed we would normally check these items prior to replacing the PCB Regards Advisor
    Sep 01, 2007 | Zanussi ZWF1430W Front Load Washer
    Zanussi ZWD1470W Front Load Washer / Dryer Logo
    543 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
