Question about Kenmore 22422 Top Load Washer
Can't remove center bolt to get off agitator. Bolt just spins.
How do I remove the bolt at the top of the agitator? It seems that the shaft it screws into just turns free and the bolt does not come out.
  • 1 more comment
  • ejs4800 Apr 07, 2008
    I have an old belt drive Kenmore 110 with the exact same problem. The 7/16" bolt just spins when i try to remove it with a socket. I believe my problem is that the dogs need replacing but cant figure how to remove this bolt for the life of me. Seems it should just spin right off, but instead just spins. I've tried holding the lower agitator, and tried laying it on it's side to see if i can find a nut on the other end that i can grab hold of but no luck.. Any help would be appreciated more than you can imagine.. (you can almost hear my wife in the background yelling: why don't we just get a new washer!!")
    thanks
  • spohn42 Apr 29, 2008
    there is no room on the sides of the bolt for me to even fit a socket over it....What should I do now? is there another way to remove the agitator to replace these "dog ears"?
  • Anonymous Dec 14, 2008
    Not enough space around the bolt to fit the socket tool I have, I guess I need to get the right tool.
How do you remove the bolt
Posted on Jun 15, 2009
    President:
  • Kenmore Master
  • 2,651 Answers
Even holding on the the agtitaor the bolt is just spinning around???? that shouldnt be. trry really taking hold of the agitator and give a good qick snap on that bolt, its actually the top of the transmission that its screwed into
Posted on Apr 05, 2008
SOURCE:
Washer wont agitate or spin
Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Aug 03, 2017 | KitchenAid Washing Machines
I have read the instructions for removing the agitator, but my machine does not seem to allow me to get to a bolt or nut. I have removed the cap from the agitator, but the barrier cap and seals do not...
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets your needs, ..Thank you.
Jul 17, 2011 | Kenmore 22422 Top Load Washer
Hello! my tub seems to be very loose and makes loud noise when spin cycle turns on....what might that be?
you will need to remove your agitator. There should be a bolt on the top center of the agitator. you will need to remove the top of agitator or the cap to get to this bolt. once you loosen this bolt the hole agitator shold pull straight up.
Now you should see the long shaft in the center. Follow that shaft from the top down to the area where the shaft disappers and ther is a big round nut with 4 notches spaced evenly. This is call the spanner nut and you should use a spanner rench to tighten it with a small sleg or hammer ( a couple of good wacks should do. ) I know you probably do not have this tool, but at least you can verify that this is your problem. your spanner nut may be loose. this nut holds your inner tub down to the block. here is the break down
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator seems to not turn right. Is there a gear that could be broken?
I'll assume that this is a standard direct drive, top loading washer. Try manually turning the agitator counter-clockwise, it should catch. if the top of the agitator spins freely, you will need to replace the agitator dogs. Part#80040 Just remove the agitator cap, (or softener dispenser) and remove the inner cap and seal. There should be a 7/16th bolt that holds the agitator onto the tranny shaft. Remove bolt and pull the agitator up from the base. Once you have the dogs, you'll see where to go from there, it's hard to explain on a post, but is actually rather simple to perform. The doga are what catches back against the grain to create the agitating action. Hopefully that's all it is.
Dec 30, 2009 | Whirlpool Washing Machines
We can't remove the agitator
Once you remove the cap on the agitator, remove the bolt and pull straight up on the agitator. It will come off the drive shaft and you can pull it out of the tub.
See the illustration below.
Regards,
Aug 19, 2009 | GE Profile WPRE6100G Top Load Washer
How can I remove the agitator on a premier 510 model
Before removing the agitator, unplug the washer to avoid an electrical shock hazard.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some washers may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
Thank you for contacting Fixya.com
Aug 05, 2009 | Hoover Nextra HNT 2135 Top Load Washer
How do you remove agitator in a hotpoint top loader washing machine
Hi. The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly, which is removable as well. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to preform a combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytag's may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
Aug 04, 2009 | GE WBSR3140DW Top Load Washer
How do you remove agitator off of a GE Prodigy
Jul 17, 2009 | GE Profile WPRE6100G Top Load Washer
Agitator barely turns, especially with a full load. It's a Roper Washer top loader.
Remove the agitator cap, some caps unscrew and some will just pull off. Look for a plastic bolt and remove the bolt, the plastic bold will have a square in the middle that the square end of the shaft of an socket extension ( or a very large flat screw driver ) will fit into the square hole to unscrew the plastic nut off...remove the upper 1/2 of the agitator....remove thebolt holding down the bottom 1/2 of the agitator, lift up on the agitator.
May 04, 2009 | Washing Machines
Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Dec 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
1,076 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
