Question about NAD T752 Receiver
NAD T752 Hi have a NAD T752 reciver. Volume goes up and down - intermittently of its own accord.Also I have a problem with the no output except for FM. This again is internmittent. And hasn't occurred for a while, just annoying.If I turn off and turn on it sometime fixes itself.Seems like the things got a mind of its own absolutely no video from component video side. volume going intermittently also.
  • Anonymous Mar 04, 2009
    I have a NAD T752 receiver and it is full of problems; this thing is the biggest piece of junk I have ever purchased. Do not repair the unit you will be thowing good money after bad. Throw it out and count your losses. Go buy a Japanese brand and be done with it.
cheebster
  • 39 Answers
SOURCE: volume and multi channel output issue
Hi there. Are you familiar with board level repair for such products ? Your problem is most likely hardware. Either some of the final output transistors are fried, or it's a dsp problem, a regulator, a diode, a transistor in the circuit.. it could be a lot of things. But if everything was working fine and it quit someday without a change in the system's setup, it really looks like an hardware issue ! Do you have a way in the manual, that sets factory defaults, a kind of reset ? A lot of such units do have that. Try to unplug/interchange speakers as well, a shorted speaker could make the amp go nuts as well, but i wouldn't bet on it. Still, i'd check that out. Hope that helps ! cheebster.
Posted on Jun 26, 2007
larry james
  • 287 Answers
SOURCE: Receiver powers down after few minutes of play
has bad 12 volt regultor and 2 5.1 volt zener diodes on the main board in the regulator circuit, also may have a few caps near these parts which also need replacing. ref # for the 12 volt reg is u703 , kinda a major job.
Posted on Sep 18, 2007
SOURCE: OSD for NAD T752
The blue screen indicates a proper connection (signal received by the monitor). Try selecting "amp" on your HTR 2 remote then use any directional button at the center of the remote, the keys which circle the "Enter" button. Hopefully you will then see the menu appear. Use the same directional keys to navigate the menus.
Posted on May 11, 2008
  • 4234 Answers
SOURCE: Intermittend no audio from digital inputs, flicker video monitor out, volume goes up but not down
Since the problem appears only after the unit has been run for a while, I'd be looking for any part close to a heat source. The odd behavior suggests that there is noise on the data lines for the volume control chip and the digital processing areas. Look for a bad 5V regulator +/or bad caps on the 5V line. Also check for poor solder connections in the power supply and final output stages.
Keep us posted.
Dan
Posted on May 13, 2008
SOURCE: NAD T752 Receiver. The unit
It's sitting on a totally open cabinent with sufficient space around it.
Posted on Sep 16, 2008
NAD T752 display totally lit up. FM sound works but no frequency display.
Sounds like display driver board {IC} has damaged. Contact any service technician. Electro help
Dec 08, 2014 | NAD T752 A/v Surround Sound Receiver
NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Mar 10, 2008 | Audio Players & Recorders
Hi, nad going but no sound from speakers. can get FM but only up towards full volume.
Checker speaker wiring on back for shorts, if okay! the audio drivers and outputs are highly suspect, at this point I suggest a serviceman because of the complexity of the surround sound system.
Apr 20, 2012 | NAD T751 Receiver
NAD T752 Hi, When powering up, about 4 second after, the amp turn in protection mode. Nothing is connected to the anp and it is clean from any metal dust. I found one transistor to be very hot. It's...
It could be entering protect mode because it has no speakers wired to it, have you tried connecting to all 6 speaker - out connections. Often, if an amp can't detect a load on all 6 channels it won't work. Also, have you checked the thermal fuses? a blown fuse could cause this problem.
Apr 07, 2011 | NAD T752 Receiver
Hi there .. i have a nad t752 amplifier , i have just got it back from the nad repair shop , they have just reinstalled it , but now the front right speaker is much softer than the left front speaker ,,...
I hate to say this but the repair was not complete. If the sound levels are different with the balance in the middle, then either they missed a problem in one of the pre-amp stages, or they used an incorrect substitution for transistors in one or more stages. This unit should be brought back to complete the repair.
Any additional detail would require that I see the actual unit and poke around inside with test equipment.
Dan
Aug 08, 2010 | NAD T752 Receiver
Keep us posted.
Dan
May 13, 2008 | NAD T762 Receiver
Right Channel Not Working
I have had the front, left and right channels go out over time. I have fixed all of them, and each time it has turned out to be a cold solder joint. While I love NAD and will continue to purchase there equipment, this generation is plagued with poor workmanship.
To fix the channel going out, I removed the top cover. Back cover and 2nd card from the left (looking at the receiver from the back side). This card handles all of the audio processing. I have found cold solder joints all over this board which has caused channels to suddenly go quite. I have never found a bad component. Also, I have cleaned the interconnect to be backplane (board that the audio processing board connects to) in the case of the center channel going quite.
If you have poor FM reception, the first board from the left (looking at the receiver from the back side) may have a cold solder joint on the coaxial connection for the FM antenna.
Apr 26, 2008 | NAD T752 Receiver
NAD C272 Amplifier: Intermittent left channel
My solution was actually indeed the output protection relay. What I did was to open up the relay and use contact cleaner and a very fine abrasive to clean the contact surfaces of the relay. After that, the problem was gone!
The way to diagnose this for me was to run the amplifier open until the problem recurred and to simply tap the relay's box. The sound came on immediately, and I was convinced.
Apr 03, 2008 | NAD C272 Amplifier
Aug 29, 2007 | NAD T752 Receiver
Receiver wont turn on
It sounds like You have a Bad output Some where and its going in to protect mode disconnect spkrs and make sure volume is Down all the way and power up,Ck your wireing for Freyed wires and shorts at the inputs and outputs good Luck ttech
Jul 09, 2007 | NAD T752 Receiver
NAD T752 Receiver Logo
136 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
