Question about Sony PlayStation Portable (PSP) Console
Psp disc error
My sons psp keeps coming up with a disc read error.tried diferent games no joy.no umd symbol is appearing and its on auto in settings
  • 35 Answers
Your PSP's laser has been damged.. You will have to get it replaced preferably by a tech from sony..
Good Luck!
Posted on Apr 04, 2008
Replace umd reader, and housing cheaper all together
Posted on Apr 10, 2008
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
No UMD icon when i load in a UMD game can hear it working inside
hi dude! go to settings then go to system settings and scrool down to UMD AUTO START and turn it on
i wish it works
Jan 13, 2009 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp error # 80010087 The game can not be started
Hi robbimic,
The first thing to check is the firmware of your PSP. You should make sure that your PSP has the latest firmware loaded. Because some games will not work or load up if the latest firmware is not installed or loaded up.
You usually get this error message 80010087 if the UMD drive has errors reading the UMD disc or otherwise the disc is not present or was ejected while in the middle of playing a game or loading a movie. I suggest that you try to testing to see if the problem happens with other UMD discs, if it doesn't then most likely the disc could be damaged or scratched.
Now if you are using a modded PSP then you will get this error if you load a game from the memory stick without having any UMD disc inserted in the drive. Or if the game that you are trying to load requires a higher firmware version installed into the PSP. You will be required to flash a higher modded firmware to fix this error if this is your case.
Hope this helps!
Peace! :)
Oct 21, 2008 | Video Game Consoles & Games
Not reading umd
your son probably dropped his PSP at the time and the UMD drive broke or if your son says he didnt drop it you can get a cutip and softly clean your UMD reader the little bubble sorta in your PSP be carful while doing that
Jul 15, 2008 | Sony PlayStation Portable (PSP) Console
PSP hanged when switch on. The usual screen appears but without the menu icons except for a small circle at the bottom right hand corner which keeps spiinning. Icons will only appear when I open the UMD...
conect your psp to you pc/lap top and find a default setting for your psps this are just like other peoples psp saved dater try that look on game sites and console cheats sites
May 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp
You could try
http://www.amazon.co.uk/GameDr-UMD-Cleaner-PSP/dp/B000BQQ2MI
If It is just dirty discs!
Apr 25, 2008 | Sony PlayStation Portable (PSP) Console
UMD Games Will Not Load
Sounds like the lazer not reading UMD's
Apr 01, 2008 | Sony PlayStation Portable (PSP) Console
Problem Running Games - no UMD symbol on console
I THINK THE OPTICAL PICK UP OF UR GAME HAS BEEN FAILURE , JUST CHANGE IT FROM ANY NEAREST SERVICE CENTER
Jan 18, 2008 | Sony PlayStation Portable (PSP) Console
PSP Can't Read UMD!
UMD games play on any unit, the movies are regional.
tiny scratches & finger prints can stop them playing look carefully at the disc.
do the discs load ok? no mechanism damage?
Dec 16, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
