FixYa.com
Tags:
Acer Altos G700 Server
Cron will not run on its own
By Ross - usenet poster
Server  is a BRAND New ACER G700 with Sco 5.0.6a   and os642a loaded  I
continue to have a problem with the cron running the backup. The only time I
can get it to run is if I change the time to within a few minutes of the
current time and then monitor it to see if it starts ......if it is set to
run at 10 PM   it will not run ......
Any Ideas ??
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 10, 2005
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
On Thu, 17 Apr 2003 13:50:44 -0400, "Jerry" <glspen @bright.net>
wrote:
(Reverted top-post)
Hmm, I see a LoneTar job scheduled for 11:30pm, but nothing for
10:00pm, which I believe was the time you mentioned in your original
post.  Is the job in question in root's crontab?  What do the other
crontab files contain?  As Ian mentioned, be sure to check email
(/usr/spool/mail/*) for any issues.
I don't see anything trying to compete with the 10:00 (or 11:30, for
that matter) time frame.
Scott McMillan
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
That link at google for the sleepy server ....fixed it   THANKS!!!
On Thu, 17 Apr 2003 09:32:42 -0400, "Jerry" <glspen @bright.net>
wrote:
----== Posted via Newsfeed.Com - Unlimited-Uncensored-Secure Usenet News==----
http://www.newsfeed.com The #1 Newsgroup Service in the World! >100,000 Newsgroups
---= 19 East/West-Coast Specialized Servers - Total Privacy via Encryption =---
Solution #3
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
 (Jerry)  17.04.03 in /comp/unix/sco/misc:
SMP?
root>> ps -ef |grep cron
Ok.. you asked for any ...
I had a (far) similar problem, when OSR5.0.6 decided one 1,3Ghz Xeon is
fast enough so the second CPU is not required and should be deactivated...
The wierd thing:
some "cron" jobs were run, but not all.
(backup works, reboot did not)
cause:
init seems to hang somewhere/died(?).
Obviously it was not respawning getty's for example,
which makes the login on serial console imposible.
(my)solution:
apply of all available patches that contains the words "fast" and "cpu",
not only rs506a, meaning oss648a so the second CPU is not turned off
anymore.
Solution #4
Not Rated (0)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
Sorry, I have moved the job all over the place to try and make it work.
Solution #5
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
On Thu, 17 Apr 2003 16:38:03 -0400, "Jerry" <glspen @bright.net>
wrote:
Accessed system at 6 am .....10 PM backup cron did not run .....idle
time  was around 5 hours.....changed cron  crontab -e for backup to
run at 6 05 am......watched log file .....backup started just fine.
/usr/lib/cron/log
<  (null) 8322 a Thu Apr 24 06:05:00 2003
 rc=1
/usr/lib/cron/log     from  10 PM
 CMD: /usr/lib/uucp/uudemon.poll > /dev/null
<  uucp 8261 c Wed Apr 23 17:10:00 2003
<  uucp 8269 c Thu Apr 24 01:00:00 2003
22:00 ....no cron even attempted to run ......this only works if the
cron is edited and then watched......
other crons are as follows:
root:
17 5 * * 0 /etc/cleanup > /dev/null
2 3 * * 0,4 /usr/lib/cron/logchecker
0 1 * * * /usr/bin/calendar -
3 3 * * * /usr/lib/cleantmp > /dev/null
1 3 * * * /etc/setclk -rd1800 > /dev/null 2>&1
#5 18 * * 1-5 /usr/lib/sa/sa2 -s 8:00 -e 18:01 -i 1200 -A
0 4 * * 0 /etc/custom -V symlinks;# CUSTOM_SYMLINK_REPORT
0 0 * * 1-5 scosh cronsched -r
0 0 * * 1   scosh cronsched -wr
5 6 * * 1-5 exec /usr/lone-tar/ltar.M.cron    <- set to run at 6:05 AM
uucp :
39,9 * * * * /usr/lib/uucp/uudemon.hour > /dev/null
10 * * * * /usr/lib/uucp/uudemon.poll > /dev/null
45 23 * * * ulimit 5000; /usr/lib/uucp/uudemon.clean > /dev/null
48 10,14 * * 1-5 /usr/lib/uucp/uudemon.admin > /dev/null
I don't know if this sheds any light on this or not.
Solution #6
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
On Wed, 16 Apr 2003 12:02:09 -0400, "Jerry" <glspen @bright.net>
wrote:
Has the system been idle for awhile at 10:00pm?  Do other cron jobs
run, or is it just your backup entry that fails?
I don't know what the Acer G700 is, but you may have a system that has
what was not-so-affectionately referred to as the 'sleepy server'
issue.  Take a look through
Also Google for 'sleepy server' in the comp.unix.sco.* groups - You'll
find others with similar stories, but not necessarily the same
solution.
Scott McMillan
Solution #7
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
Here is one additional item :
root> ps -ef |grep cron
          root 21391 18976  3 09:29:33 tty1A00    00:00:00 grep cron
          root 15815     1  0   Apr-07       ?    00:00:01 /etc/cron
root> uptime
  9:29am  up 5 days, 20:10,  16 users,  load average: 0.02, 0.01, 0.00
root> date
Thu Apr 17 09:29:51 EDT 2003
System rebooted on April 12 th.    the cron has been running since April 7
th.....
Any thoughts?
Jerry
Solution #8
Not Rated (0)
Cato
Cato - usenet poster
Rating: 0%, 0 votes
results of
root> crontab -l |cat -v
#       @(#) root 90.1 00/05/01
#       Copyright (C) 1989-2000 The Santa Cruz Operation, Inc.
#               All Rights Reserved.
#       The information in this file is provided for the exclusive use of
#       the licensees of The Santa Cruz Operation, Inc.  Such users have the
#       right to use, modify, and incorporate this code into other products
#       for purposes authorized by the license agreement provided they
include
#       this notice and the associated copyright notice with any such
product.
#       The information in this file is provided "AS IS" without warranty.
30 23 * * 1-5   exec /usr/lone-tar/tar_test
Solution #9
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
Scott,
First thanks for the quick reply,  By 10 PM the system has normally been
idle for 4 hours,  I started the cron log to see if other jobs were
running....they are running fine....these were the standard SCO crons from
install. Near as I can tell it is only the backup entry that fails ....I
also put just a plain  tar entry in the cron ....tat also did not run.....
Dazed and confused...
Jerry
225%40mammoth.ca.caldera.com
Solution #10
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
<stuff about a cron task not running>
Thought #1: Have you already checked root email for any messages about
problems with the cron entry?
Thought #2: What exactly is the output of
$ su - root
# crontab -l | cat -v
Ian Wilson
Can you Help with these Servers problems?
Servers
sxe not work
sir tell me plz my sxe injected... Answer This...
Servers
Hack
Counter Strike Sxe Hack Answer This...
Servers
torrent download problem
I am using internet for last... Answer This...
Servers
I.T Warning
i cant open my tagged messages,... Answer This...
Servers
it won't let me pay my bill
I always pay my bill on line.... Answer This...
Repair Service
Find Server Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
