Question about Toshiba Satellite M65-S9092 Notebook
Motherboard when I start the computer I have the option of pressing F2 (open setup) or F12 (run service device, somthing like that) When I run service device I get the four options HDD, CD/DVD, LAN, .... I chose HDD and then I am told operating system not found. Finally I recieved this message... "System configuration Data Error - Error" "System configuration Data read error - error" "Resource conflict - PCI network controller on motherboard" "BUS:06, Device:02, Function 00." So is my mother board fried? If I need to replace my motherboard what are my options for upgrading the motherboard and video card.
  • 1 more comment
  • o0JMH0o Apr 04, 2008
    forgot to mention, it is a toshiba satellite m65-s9092
  • o0JMH0o Apr 05, 2008
    I am stationed in Afghanistan and we had some unexpected rain and my tent leaks. I got to the computer pretty early but there was a little puddle of water on the lid and it looked like the water was dripping right where the external harddrive USB connection is. So I am pretty sure that water got inside I just dont know how much of the computer is destroyed. Just seeing what people thought before I started to rip it apart and use what I could.
  • o0JMH0o Apr 07, 2008
    Well when I take out all the screws in the bottom and the coupl eon the side, I am able to get all the sides up but it seams like there is a screw holding the middle together. I look on the back and can not see any more screws. I poked all the stickers to see if there where screws under them but didnt find any (should I have found some?). Or do i just need to stop being so gental and just rip it apart.
  • 77 Answers
Try dismantling your laptop and one by one remove the module components like the Wifi card, Lan modem module (if possible) and try booting it up again and see if this problem will be solved.
What did you do prior to experiencing this particular problem?
Posted on Apr 05, 2008
  • Philip Tan
    Philip Tan Apr 06, 2008
    well. water damage is a very hard situation you are in. if i were you DONT use your laptop for the meantime. if you need to access your data then just remove your HDD nad plug it another machine. for your laptop. if you dare, then open it up and see if there are any busted components. If you see some corrossion then, try cleaning it using some solvent and dry it up thoroughly then assemble it back and see what happens.
    if the problem persists, then most likely you need your mobo repaired or even replaced
  • Philip Tan
    Philip Tan Apr 08, 2008
    toshiba normally has a screw on top of the keyboard.
    try to see if you can remove some plastics on top of the keyboard. upon removing it, there should be screws underneath. Dont ever force the laptop or (ripping it apart). you will be doing more damage than cure
SOURCE:
SOURCE: Resource Conflict - PCI Network Controller in Slot 02
check for an update of bios on acer.com it will fix your laptop problem....
Posted on Apr 24, 2008
I was on this forum because I was having the same issue with a Toshiba A75 "Laptop", and I tried everything on here and on other forums and no luck. I actually just accessed the integrated wireless card panel from the bottom and removed it from its slot and disconnected the wireless wires connected and put it back on. So this has worked for me and my machine post perfectly now. Good luck to all and I hopefully this will be helpful too you.
Posted on Aug 29, 2008
Kiranbala
  • 91 Answers
SOURCE: My laptop wil not boot. Not even in safemode
I guess the RAM is not working properly....... 2 beeps indicates RAM failure... i suggest you to take the notebook to service center and get repaired...
Posted on Jul 22, 2009
  • 1087 Answers
SOURCE: Al encender mi ACER Aspire
You have a n IRQ conflict meaning you have a device that is trying to use an IRQ slot that its not meant to talk on. From the looks of it you have been in the bios already so go back in and set it to factory default.
Posted on Aug 16, 2010
alien_x
  • 281 Answers
SOURCE: I have Acer Aspire 5101
you need to flash your bios with a new version try the laptop manufacture's site.
Posted on Nov 02, 2010
How can I start when Default boot device missing
Good day Ken Markham
If your "Default Boot Device" is your hard drive and it is missing, then your machine will not start, you may need to have a technical person look on your machine for you.
Nov 20, 2014 | Computers & Internet
Gateway sx series sx2110g-uw318 boot menu
This is an snippet from the Gateway Website.
"In order to access the boot options on this portable computer, press the ESC or F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives or to enter the BIOS Setup Utility. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer."
Jan 26, 2014 | Gateway SX2110G-UW318 Small Form Factor...
How do I know if my boot ste up is correct
If your PC doesn't boot up using the hard drive, you can check that by looking for the F2 or F12 displayed on the screen during boot up. Then start pressing F2 or F12 quickly to get setup.
In setup follow the directions and set your "boot device" to "hard drive"
Hope this is what you needed.
Feb 15, 2012 | Dell Inspiron 531 Athlon 64 X2 4400+...
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
May 15, 2011 | Dell Latitude CPI-A Notebook
Windows wont start. dont know how it happened.
Does F2 mean to enter setup or does F12 mean to enter setup, Press the particular key on the keyboard to enter setup and Go to Exit using your up-down keys on the keyboard (it varies with different motherboards) and go to Load Optimized Default then Yes and press F10 - Yes and it will automatically restart the system, b2.jpg if both are not displaying anything to do, restart the system and press Delete button and follow the same instructions as mentioned above. (If the BIOS screen is similar as displayed above, then just highlight the Load Optimized Default using your Up and Down Keys on the keyboard {Y for yes, Enter for OK}).. It's will boot from the hard disk as default not from the CD-rom..Good luck...
May 10, 2010 | Dell Inspiron 530 Desktop Computer...
How to enter to boot menu
Try to press F12 during startup. You need to press F12 before windows starts to load.
Another option is press F2 during startup and change the boot device in the boot device priority section.
Done that Save and Exit setup
Mar 13, 2010 | ASUS F3Jm Notebook
Bios setup doesn't work and when i pressing f2 the bios doesn't appear and white sign come on the corner
Try pressing repeatedly very fast untill it does, or maybe it uses other keys like F11 F12 or DEL?
May 21, 2009 | Intel D101GGC Motherboard
Laptop A3 not booting up
Sounds like your hard drive is not booting and that your keyboard isn't responding to your pressing F2 and F12. If you can locate a USB external keyboard or if you have a round PS2 port for an external keyboard/mouse - plug into the laptop with that then press F12 while the computer is booting, press it a few times to be sure you get it in the buffer - then the boot manager should show up. If it does, choose to boot the Hard Drive if available - same with pressing F2 - Setup or Bios CMOS Settings should be displayed, here you can try to boot from the Hard Drive or Check to see if the hard drive is being recognized or not.
You may need a new keyboard if your laptop keyboard doesn't get you into either menu, and to either make sure your hard drive is responding and can be set to be the default boot device.
Mar 23, 2009 | Toshiba Tecra A3 Notebook
Boot from cd
when u power up the computer press DEL or F2 or F10 F12 key to enter bios setup.
then go to boot option then set your dvd or cd as first boot device.
Nov 30, 2008 | Intel Motherboard
Can not Boot from OnBoard SATA Hard drive.....it keeping looping...
Turn on (or restart) your computer.
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F12>.
The Boot Device Menu appears, listing all available boot devices. Each device has a number next to it.
At the bottom of the menu, enter the number of the device that is to be used for the current boot only.
If this works and you want to change the setting permanently do the following:
When F2 = Setup, F12 = Boot Menu appears in the upper-right corner of the screen, press <F2>.
Use the arrow keys to highlight the Boot Sequence menu option and press <Enter> to access the menu.
NOTE: Write down your current boot sequence in case you want to restore it.
Press the up- and down-arrow keys to move through the list of devices.
Press the spacebar to enable or disable a device (enabled devices have a checkmark).
Press plus (+) or minus (–) to move a selected device up or down the list.
Feb 17, 2008 | Dell Dimension 4700 PC Desktop
Toshiba Satellite M65-S9092 Notebook Logo
1,026 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
