Question about Sony KP-51HW40 51" Rear Projection Television
Intermittently convergence problem.
After the power on the screen shows bad convergence problem ,it will stay bad for a little while then back to normal pix,but it will go bad again ,on and off ( intermittently ),and then stay good pix.
Please guides me how to fix it ,thanks a lots.
  • Richard 123 Apr 20, 2008
    Hello :
    How are you doing? Frist of all I would like to thanks for your help,yesterday I open the tv to retouch - up the solder joints of those two IC's ( STK 392 - 560 ) ,but it's not kill the problem,for the next step will be taken as your recommended to replace those two IC's,but I don't know where I can find the IC's and really good price,can you help me again,please.thanks a lot.
    Best Regards
    Hi:
    It's me again,I forgot one question,after replace the IC's ,do I need to do something els? such as realignment anything?
    Thanks.
Hello:
Finally my Sony KP-51HW40 got fixed, according your instruction,it just replaced two of'm ( STK 392-560 ) then convergence problem has been solved ,and I don't need to do any adjustment.
If rated 10 ,I will give you 10. Thanks.
Posted on May 23, 2008
  • Sony Master
  • 8,617 Answers
Try resoldering both convergence ICs located on the D board if that doesnt correct the problem you will need to replace both ICs let me know if I can assist you further.
Posted on Apr 10, 2008
  • Sonny Berry
    Sonny Berry Apr 21, 2008
    you can get replacement Ics at the following link you will need to do a final adjustment after replacing the ICs. Youcan get replacement ICs here
    http://servicemanuals.vstore.ca/
SOURCE:
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Toshiba TW40H80 40"
ok! maybe you have defective convergence correction circuit! sir do you have experience in electronic repairing?
Oct 11, 2007 | Toshiba TW40H80 40" Rear Projection...
The convergence doesn't stay put
Mine's doing it too. Bad convergence amp IC's. STK392-020
Jun 24, 2009 | Philips 50PP9202 50" Rear Projection...
Intermittently screen move to one side with distrited picture
Might be the convergence chips. Do you have any problem moving the convergence under the menu setting? Convergence chips are reasonably priced. If you know a friend or someone who can solder better than average, I would go this route. My tv wasn't that bad; I wasn't able to set 2 of the 3 colors during convergence setup. Changing the 2 convergence chips did the trick!
May 24, 2009 | Philips 43PP9202 43" Rear Projection...
RCA D52W17 won't stay on.
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Tv problems
Unplug the three red-blue-green plugs nest to the convergence amps. If the unit powers up and stays on the picture will look bad but will confirm that the convergence amps have failed...
Replacing the amps and one or more resistors in the yoke return will restore the set to normal operation..
Use only Sanyo original Ics..
Bill
Oct 11, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Convergence problem or??
Yes it has power supply and convergence problem let me know if you need help with part # s or how to fix it
Jun 23, 2007 | Samsung PCN5425R 54" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
