Question about Visonik V117SX Car Audio Amplifier
Amp problems I have a visonik amp, hook up was pretty easy, the problem is I can on hear music when using the radio on the head unit, when I use the c.d or i-pod nothing comes thru the subs.When I use the c.d or i-pod the power light goes off.
  • 631 Answers
The head unit probably has 2 control wires. One has 12v when the signal source is the tuner. When you switch to the other sources, the antenna is not needed so the output to that wire is switched off (so the power antenna will go down).
Look for a wire marked amp control or something similar. It will have 12v output any time the head unit is on. Use that one to control your amplifiers.
Posted on Apr 05, 2008
SOURCE:
I have a couple of questions regarding my jl 500/1. the first question: i just transferred my amp/subs (subs are JL W3s) to a new vehicle, and the place i had install it switched the "high/low"...
ok..well theres a lot of question in there, lemme take a shot at it.
the hi/low switch explained: the hi/low switch tells the amp what signal voltage is being delivered to the amp...hi-power (4-15volts) or low-power(micro-volts). Your aftermarket head unit had what are called pre-outs (or preAmp outs) meaning the source signal (your music) is not amplified before being delivered to the amplifier...sooo...your amplifier setting for your aftermarket radio would be 'low' to tell the amp that the music source being sent to it is low-voltage.
Typically a manufacturers radio will not have pre-outs, they will be amplified by the radios internal amp to anywhere from 4volts on up, and you need to tell your jl audio amp that the source music being supplied is 'hi' voltage.
soo...of course...if you are sending 10volts to the amplifier and tell it that your sending micro-volts (low setting) your amp will over-amplify the signal and thus the overwhelming bass you experienced.
May 14, 2011 | Jl Audio 500/1 Car Audio Amplifier
On my recently installed Jensen VM9414, while playing a DVD, I can clearly hear the background noise/music, but I cannot hear the characters voices. I thought maybe it was the setup but have tried...
I've had this problem before, but not on this specific head unit. You most likely have your audio setup to 5.1 or other surround format, yet have nothing hooked up to the center channel output of the head unit.
Unless you've currently hooked up the center channel to an amplified speaker, or gotten out of a surround mode, you're not going to hear anything.
If you do have everything hooked up right and are sure the settings are correct, possibly a blown amp in the head unit.
Feb 28, 2011 | Jensen Vm9414 Car Video Player
Everything works fine when i play a cd it works it reads it but dont hear the music when i turn to radio i hear the music,just wondering what could be wrong help me out thanks..
First off how long have you owned the unit? Did you buy it new? Did it ever work playing cd's? it sounds like either a setting problem or a hardware problem with the unit. Once I have more information I can assist you further in trying to isolate the problem.
Thank you,
Lee
Mar 31, 2010 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
No Sound From Speakers
Replace the 37 year old radio, it has retired.
May 20, 2009 | Cadillac DeVille Cars & Trucks
Need to know what connections for 6 pin input port
honestly anything made by visonik is **** and i wouldent try wiring it like that it could have bad consequences do rca or call visonik and order a replacement
Apr 26, 2009 | Visonik V117SX Car Audio Amplifier
Visonik amp problem... amp goes in and out of protection
Check for intermittent shorts on the speaker leads.
Turn down the volume control on your head unit while operating the amp, you could be over driving the amp.
Remove Speaker leads and reset the amplifier. IF the protection LED still comes on amplifier is faulty.
Below is the link to put in a help request with the manufacture for repair.
http://www.visonikcaraudio.com/category.jhtm?cid=27
Mar 25, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Visonik 350watt Amp Doesnt Come On....
With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Oct 06, 2008 | Visonik V117SX Car Audio Amplifier
Ok this problem is killing me...
maybe the speaker is bad
First try one thing, switch the rca jacks around and see if the other speaker stops working this time.
If so the problem is in the rca jack or head unit.
If the same speaker is still not working, the problem will be the speaker, you will have no other options left since you changed amplifiers and checked all wiring.
Let me know if this helps you
Jun 18, 2008 | Visonik Dual Bass Box with Amplifier Car...
CDs and Ipod wont play with Alpine CDA-9885
The Alpine has two tigger wires when it turns on. One is an AMP TURN ON wire (blue/white) and a PWR ANT wire (blue) and that wire only comes on when using the radio or an optional HD radio unit ... When it was installed/connected . someone hooked your amp turn on wires for your "full range amps" to the PWR ANT wire. And the sub amp trigger is either hooked correctly to the AMP TURN ON WIRE or somewhere else, it probably shouldn't be... Check it. Amp triggers should all be to the blue/white wire from your alpine. Warning: Alpine trigger wires, are very easy to mess up they supply a very limited amount of power.
Apr 28, 2008 | Alpine CDA-9885 CD Player
Sub cuts out when I switch to CD player?
It shuts off because the remote turn-on wire to the amplifier is connected to the power antenna wire behind your head unit. The power antenna wire is only activated when the tuner is selected. You need to switch the remote wire to the blue/white wire from the head unit (currently you're using the blue wire). This is the true remote output, and will activate the amp whenever the head unit is powered on.
Jul 06, 2007 | Alpine CDA-9885 CD Player
Visonik V117SX Car Audio Amplifier Logo
126 people viewed this question
Top Visonik Car Audio & Video Experts
Mike Duncan
Mike Duncan
Dalynn Turner
Pierre Laplante
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
