Question about Refrigerators
There's a loud humming in my danby kegerator after about 25 minutes of being plugged in. Everything was fine for about 2 months. The model number is DKC645BLS. Any ideas would be welcome.
  • 24 Answers
Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. When it doesn't run, the fridge and freezer don't cool.
Posted on Nov 08, 2009
  • 725 Answers
Maybe a locked up compressor...is it cooling at all?
check your owner manual but it should have a 5 year sealed system warranty..
Posted on Apr 05, 2008
Just plugged in my new 12 bottle Danby wine cooler and it hums, LOUDLY. Any idea why?
it might , it has a compressor and that would make more noise under a strain . refrigeration units strain when the box is warm. let it run and bring down the temp of the box and then see how much noise it is making . 12 hours should do it.
Jan 30, 2016 | Danby DWC1233BL-SC 12 Bottle Wine Cooler
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
My kegerator out of the blue starts making noises?
Good chance the compressor is going bad. It will likely die shortly.
May 03, 2014 | Danby DKC645BLS Compact Beverage Cooler
I have a Danby which has the feature for heat on the left-hand side. I just bought it a month ago, but can't lay my hands on the instruction book right now. Can you tell me the proper procedure for...
Lori, the Danby Humidifier, Model # DDR2504 does not have a heating function. It's just a 25 pint dehumidifier. In fact, there are no Danby Dehumidifiers that have a heating function.
By, chance do you have Multifunction Air Conditioning unit, rather than a dehumidifier? If so, please provide the correct model number.
Thanks for choosing FixYa.
Sep 11, 2011 | Danby DDR2504 Dehumidifier
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need... mark.pasieka@gmail.com
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
I have a danby premiere model DPAC10071 & the dehumifier now wont fill external tank. every 2-3 minutes it makes a noise kind of like a fog horn way off in the distance(as if its trying to run again,...
it sounds like your compressor is failing to start ... that usually means a bad starting capacitor ... if thats the case it will hum loudly for a few seconds periodically .. thats the compressor trying to start but it cant if the capacitor is bad .. it will stop humming when it gets too hot .. a thermal breaker will turn off the power until it cools back down .. dont let this continue since it will eventually damage the unit ... replace the capacitor .. the capacitor is usually mounted on or near the compressor .. it often has two sections .. one for the fan motor and one for the compressor ... since they are both in one case you have to change them both ,...
Aug 15, 2010 | Danby Heating & Cooling
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Kegerator not keeping beer cold
insulate the tower with pipe insulation, there is a hole in the bottom of the tower. don't over insulate or it will freeze.
Aug 12, 2008 | Refrigerators
Refrigerators Logo
282 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
