Thanks, I'll call my old ISP!
What do I check to make sure the network connect is disabled? How do I test the modem?
  • fourltrwrd Apr 08, 2008
    I ended up having a pc repair man try two other modems and he kept getting a plug and play error - not one of three modems ever dialed out. He's trying some other trouble shooting procedures, but thinks it's a motherboard problem. thanks for all your help
    President:
  • 778 Answers
Your ISP's proprietary software should detect whether your modem is getting dial tone or not, so that's how I would check the modem. Another way to test the modems connectivity would be to connect an active phone line to the in port and a landline phone to the out port and see if the phone gets dial tone?
I don't think you need to worry about disabling your network connections as there should be no conflict especially since you have no network cable attached (your ethernet/networking card will sense a connection or not).
Keep me posted.
Posted on Apr 05, 2008
  • Frank  Fernandez
    Frank Fernandez Apr 09, 2008
    You're Welcome, good luck, and Thanks for the rating.
Cant connect to any web..
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver you might see a yellow question mark? This means you need to update the driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
Jul 12, 2011 | Computers & Internet
Just bought new linksey wrt120n followed instructions to when you plug in. no lights come on at all tried different socket still no lights.
also
hope this helps
Jun 29, 2011 | Computers & Internet
I have a problem on my internet connection through my dell laptop... its already detect but the internet never run. i have 1 pc. but the pc system is running. thanks
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
hope this helps
Jun 17, 2011 | MSI 945P Neo3-F (7236-040(945P NEO3-F))...
Internet is not working .system is lenovo 8280 desktop
also
hope this helps
May 20, 2011 | Intel D865GBF Motherboard
Wil not get on the internet
also
you might have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
hope this helps
May 01, 2011 | Computers & Internet
Unable to use LAN
if you are reffering to your internet connection
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
also you might check
hope this helps
Apr 12, 2011 | Computers & Internet
Can't connect to internet
also
click start control panel administrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
hope this helps
Apr 08, 2011 | Aspire Audio Players & Recorders
I can not fully access my internet
also
hope this helps
Apr 04, 2011 | MSI MS-6547 Motherboard
MODEM CONNECTION NOT FOUND
hope this helps don
Feb 25, 2011 | Computers & Internet
LOCKED MODEM??
ru using a cable connection or a dsl connection?
what you can go is reset the modem and then try.if it is a cable connection then your isp settings is automtically picked up by the modem but if it is dsl and if your isp has given you user name and password check if it matches with the earlier details...
im sure it is not a hardware issue as i have worked with the a reputed isp company so probably they have changed the settings which you old modem doesnot identifies,so we need to configure the old modem..
vedhick...
Feb 23, 2009 | Motorola Computers & Internet
Computers & Internet Logo
46 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
