Question about Microsoft Windows Vista Ultimate Edition
Vista patch i want to buy print shop and it says i need a vista patch what do i do
  • 74 Answers
Download free patches from
www.crack.ms
or seach in google free patch for vista.
ur's kishore chowdary.
Posted on Apr 05, 2008
SOURCE:
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
I have a new computer with 'Windows 7' installed. I would like to run 'Print Shop Deluxe 22' Is there a patch to make the program work? I need a simple fix. Hope someone can help me. Cheers.
You can use the Windows Vista Compatibility patch which works equally with Windows 7.
You can download it here.
When the download is complete, close the Download window. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update. Then follow the onscreen instructions to complete the installation.
After the patch being installed, you can
launch and use The PrintShop® 22.
Hope this helps!
Apr 09, 2011 | Broderbund The Print Shop 22 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Cannot load easy creator 10 onto vista
i Think you do not have vista compatible softwares i.e.
Roxio Easy Media Creator 10 Suite . So please buy vista compatible software or path with vista patcher . You can easily download vista patch from www.rapidlibrary.com . Patch and run the software in vista. Best of Luck.
Nov 06, 2009 | Roxio Easy Media Creator 10 Suite
Activation patch
You shoul try p2p sites like btjunkie.org
But the best solution is to buy your license. There are some retailers that offer you a free upgrade to win7 in case you buy from them a vista license
Aug 25, 2009 | Microsoft Windows Vista Home Basic Edition
HP Bus Inkjet 2800 won't print 11x17 with Vista
Many people had a similar problem with the Color Inkjet cp1700 B-size printer.
Vista Patch for cp1700 Printer - Fixes Duplex and Large Format Printing
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=2916&
General page with links to the cp1700 and other printers as well.
Vista Duplex Solution - Back Page Upside Down
http://h30434.www3.hp.com/psg/board/message?board.id=Software&thread.id=43
and
http://www.vistax64.com/vista-print-fax-scan/172813-cannot-print-wide-format-hp-cp1700-2.html
Another solution that worked for some people was installing the hp deskjet 9800 printer driver.
It appears what you need is a patched .gpd file for the BI 2800.
Try emailing Bob Headrick, who has done these patches. (Thanks Bob)!
Be sure to put Vista and Large Format Printing 11x17 in the subject line.
[email protected] (or see his profile for email address)
Bob Headrick, Microsoft MVP Printing/Imaging
You'd think between HP and MS, they'd have this working right out of the box.
Did they think people would buy a B-size printer so they could hook it up to Vista and then not want to print mainly B-size documents?
They would have had happier customers if they would have included B-size support but left out A-size!
Amazing!
Good Luck
Jun 05, 2009 | HP Business InkJet 2800 Printer
I am fairly new to PCs. I recently purchased a Toshiba 205 and have Vista SP1.  I purchase Print Shop Delux 22 and started the installation process before I read the statement about don't start...
Hello, Encore Software has released a patch to make Print Shop Deluxe 22 compatible on Windows Vista.
Here is what they say here:
http://support.encoreusa.com/kb.asp?id=571
Problem I am looking for the Vista compatibility patch. Solution This Windows® Vista update will detect and repair The Print Shop® 22 and PrintMaster® 17 applications already installed on your computer. After applying this update The Print Shop® 22 and PrintMaster® 17 will operate normally on computers running Windows® Vista.
Update Instructions
1. Click the link located at the bottom of this page.
Note: For Microsoft® Internet Explorer® the File download dialog may appear. Select Save this program to disk and click OK.
2. Choose a location (e.g., the Desktop) and click Save. The download process will begin.
3. When the download is complete, close the Download window.
4. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update.
5. Follow the onscreen instructions to complete the installation.
Note: Depending on system or user account settings, you may encounter several interruptions during the installation process. If so, please click Continue or Allow in order to proceed.
6. Launch and use The PrintShop® 22 or PrintMaster® 17.
Click here to download Broderbund_Print_Update.exe (26.7 MB)
Aug 21, 2008 | Computers & Internet
Vista patch for "The Print Shop version 10" by Broderbund.
Here is link from Corel for pathes of all their products.
Try it (From Corel Draw)
You may also download from following links.
Click here
Thanks
Iqbal
Mar 17, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
