Sony DVD RDR GX350 remote control code for Sharp TV
Sony DvD model RDR GX350 Remote control, is not working with Sharp TV, need code please could you help
5 Suggested Answers
  • 518 Answers
SOURCE: remote control codes for naxa tv model nx -524
You neglected to post the Remote's Make and Model. However, most Univ. remotes allow you to "Scan" the TV codes one at a time. You would do this and watch for the TV to turn off. when it does, you have the code and can store it.
Geno
Posted on Mar 05, 2008
superminer
  • 26 Answers
SOURCE: Remote for DirecTV wont control my Toshiba VCR/DVD combo unit
Its true sorry but there isnt any codes available for combos.
Posted on Jul 19, 2008
SOURCE: changing remote command mode for sony rdr-hx525 without remote control
Hold the "Enter" button along with the numeric button for the command mode you selected in Setup. This will reset the remote to work in the command mode you selected (also lets you get back into System Menu to try other command modes). If you pick a different command mode, you'll need to do this again to reset the remote to the selected mode. Found this info courtesy our friends on the Internet - no thanks to Sony's manual...
Posted on Aug 16, 2008
dvinnedge
  • 35 Answers
SOURCE: Need product codes to program Universal Remote
I have the following toshiba codes
10154, 11256, 10156, 10093, 11265, 11060, 11356, 11369, 11524, 11635, 11656, 11704, 11918, 11935, 11936, 11045, 12006, 11343, 11325, 11306, 11164, 11156, 10845, 10832, 10822, 10650, 10149, 10036, 10070
Posted on Nov 29, 2008
  • 96 Answers
SOURCE: Have lost instruction manual for our DVD Recorder
Hi. You can download user manual as PDF file at http://safemanuals.com/user-guide-instructions-owner-manual/SONY/RDR-HX510-_U
(just press on Adobe PDF icon. When the new window
pop-ups copy the 4 falling numbers. Then "Download the user guide" button will appear active.
Good luck and rate my solution!
Posted on Feb 14, 2009
Need codes for setting up my Dish VIP 612
Ed Fox,
I can definitely understand the concern. Below I will give the steps to program a remote to an auxillary device, a link where you can look up codes, and the steps on how to preform a Power Scan if the codes don't work.
Codes: http://www.mydish.com/support/apps/remotecodes.aspx
Addressing Remote:
1.) Press and hold the clear DVD button until all mode lights light up.
2.) Release and DVD light will be blinking.
3.) Press 1 for a VCR/DVD, and enter the code. (if DVD code is 617, enter 1617)
4.) Press pound (#)
5.) Try functions (Power, Play, etc..) and see if it is working.
6.) If no function, repeat steps 1-4 with another code.
On the steps above, to program your sound bar, repeat the same steps but instead of DVD hold AUX, and instead of 1 before the code, press 2.
To Power Scan the remote, with the desired equipment on, press and hold the DVD or AUX mode button (about six seconds) on the top of the remote until all mode buttons light up, then release. Press 1 for VCR/DVD, or 2 for other equipment, then press STAR (*)
Press the Up arrow button once per second while pointing the remote at the equipment. If the code for it comes up, the equipment power off.
When it does, press the POUND (#) button. If the code entered is valid for the remote, the mode light will flash three times. To verify the code works try several different functions for that equipment.
Let me know if you have any other questions!
Tommy Faust
DISH Social Media Representative
Mar 05, 2013 | DISH Network ViP 612
I just got a new Dish VIP 211K system. I am having trouble programming the Dish remote to control my Sony DVD-R/VCR combo system. None of the codes in the book are working with it. I need to program it...
Hello, Cheri Torres with DISH Network Customer Service here.I came across your post and wanted to see if I could help. We have a fewdifferent codes for each of our different models of remotes. I will list herefor you the best codes for the more popular models of remotes and also theinstructions for addressing the remote to the TV. The best codes for the SonyDVD/VCR are 817, 778, 818, 768,005 and 002. I hope you find these codes andinstructions useful but if you do not I will also list here for you theinstructions for running a power scan which can sometimes find the code foryou. If you have any other questions or concerns feel free to email me atCheri.Torres@Dishnetwork.com. :)
Instructions for addressing your remote to your DVD/VCR
  1. Press and hold the desired Mode button until all mode button backlights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
    • Press 0 for a TV
    • Press 1 for a VCR/DVD
    • Press 2 for any other device.
  3. Press the pound (#) button Note: The light will blink off after each digit is entered and then return to a steady light.
  4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Instructions for running a power scan
  1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
  2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
    • Press 0 for a TV
    Then Press STAR (*)
  3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
Feb 09, 2011 | DISH Network ViP 211 DTV Receiver
I have dish network and a new rca tv with dvd the
You can power scan for the code.
Turn ON the electronic device you want to program the remote to control.
Press the Mode button( sat,tv,dvd,aux) on the remote until the appropriate mode light is flashing.
Press the Power button. The mode light will stop flashing and stay lit.
Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
Press the pound key button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
Turn the device back ON by pressing the Power button.
Press sat mode key once you power back on the tv to be able to operate the receiver box.
Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
If the other buttons work you are finished.
If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Mar 11, 2010 | DISH Network 322 DTV Receiver
How can i program the Humax remote control (RM-F01) to work with my Sony TV and DVD
In the Setup Menu, Go to Remote,
Select your TV Type and try the different codes.
Jan 30, 2010 | Humax DRT800 TiVo Video Recorder
I NEED TO KNOW HOW TO GET AND WORK CODE FOR UET609 UNIVERSAL REMO
n these remote controls any device key can operate other device types because coding is by selecting a number from a list ranges for UET609 - tv: 000-268 and 700-758, vcr: 269-370 and 750-758, sat/cbl: 371-523 and 800-883, aux (cd, dvd etc): 524-699.
As there are 800 codes, select the appropriate device before searching for a code! This presets the start position in the search.
To set a code:-
Press and hold [set], press device key - red led lights. Release keys. Enter 3-digit manufacturer's device code from the list. Led goes out and the code is set. If it doesn't work try another or search.
To search for a code:-
Turn on consumer device!
Press and hold [set], press appropriate device key - led lights - release keys - press [set] - led blinks. Press [power] key repeatedly till device is switched to standby - press device key to store the code. If, after releasing the keys, [set] is pressed twice, search runs backward through the list.
Having found the code, it may be useful to write it down, as follows. Press and hold [set] - press [1] and release. Count and record the number of times the led blinks - release [set]!. Repeat for [2] and [3].
Note! The above information is from the manufacturer of the remote controls. In practice, things may be a little different i.e. on the UK Sagem digibox [power] is digit 1 and the power key is [tv/txt]!
These controls can be regarded as old stock and may not contain codes for digiboxes and DVD drives. However, surprising things happen, if a manufacturer is using old codes. The Goodmans GDB3 digibox can use UET609 sat/cbl code 424 and the Sagem ITD59G can use unlisted code 836.
To repeat, the protocols and associated key codes are referred to by a 3-digit control code, taken from a list of 800. You should find the necessary code fairly quickly - within 100 tries, if you select the correct device type.!
There is at least one more remote control in this series and operation should be the same, though the key layout varies between models.
At times, these remote controls can malfunction.
Red Led stays on - Remove the batteries and re-insert them.
Remote Control suddenly stops operating - make sure correct device key is selected. If necessary, re-enter the relevant device code. If this fails leave the batteries out over-night and re-enter the codes.
Codes: 044,054,119,124,196,198,225,227.
If it works vote for me
Aug 17, 2009 | Televison & Video
I want to adjust my LG remote control to my Sony tv
I found the DVD LG DVS-8575N manual in spanish on http://safemanuals.com/user-guide-instructions-owner-manual/LG/DVS-8575N-_S
To set a Sony TV just press at the same time POWER TV and number 8 or 9
Jul 10, 2009 | Sony Televison & Video
Feb 19, 2008 | Directv D10 DTV Receiver
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
Electro Med Services...
