Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica water dispenser not working.
How does the blue quick disconnect behind the kick panel function (twist?, pull?,...?)
  • 725 Answers
Push ring around the tube toward the connector and pull out the tube..
hope this helps
Posted on Apr 05, 2008
6ya staff
SOURCE:
I have a GE Profile Arctica and the ice and water dispenser do not work. The ice maker still functions, just not dispensing.
HI. first i would check your water supply since both r not working..try this first good luck.Ali
Jun 25, 2012 | GE Refrigerators
GE Arctica pss25sgmd compressor wont kick on...any reasons why?
There is a really good article I read a few weeks ago on this site below.
http://www.appliancerepairlesson.com/
The most likely reason is the main control board, this board is located on the back of the unit behind the thin metal cover. If you have a volt meter we can test the control at the link above.
Mar 02, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Ice/Water dispenser not working on my GE Profile Arctica model # PSS26SGPA SS. Does make ice though, just front panel stopped working. Called a tech to troubleshoot, who said it was the main...
Had same problem. Removed kick panel at bottom and found the wires from the freezer door near the lower hinge are very flimsy. The white wire was broken at the connector and the connector was corroded. Since I have no plans to remove the freezer door, I spliced the wires together with **** connectors and it's working fine.
GE could do better.
Jan 12, 2011 | GE Profile PSW26P Stainless Steel Side by...
GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Dec 09, 2009 | GE Profile¿ Arctica® Energy...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile Arctica Side By Side refrigeratorand the water despenser is not working. I have narrowed the problem down to be a frozen waterline, but it is not frozen in the frezer door. The line is...
There may be an issue with the water dispenser line freezing in this model. The fix for it might be this dispenser water tube heater kit # WR49X10173. Hope that helps you out and best of luck
http://tclaundryrepair.com/
Feb 25, 2009 | GE Profile¿ Arctica® Energy...
GE Refrigerators - Water dispenser not working ? I
remove front grill then disconnect the water line at the quick connector. Place line on right side into container and push lever for water. If no water flows the problem is a solenoid on the left side of the back of refrig behind lower panel. If water flows into container the problem is related to freezing of the water line in the freezer door. GE fix is a $500 plus door replacement. Thaw from back of door behind the dispenser with hair dryer (do not get plastic too hot). Cheap fix is to insulate back of door with insulation such as a foam sleeping bag mat or the foil and bubble wrap type of ducy insulation
Nov 16, 2008 | Refrigerators
GE Arctica
there is a board in the back right side behind a panel embedded in the back of the unit just above the back cover. it is a Part # WR55x10552 this is most likely your problem it controls all functions of the unit
Aug 01, 2008 | Refrigerators
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
54 people viewed this question
Top Refrigerators Experts
Brad Goodale
Jeff sanchez
Level 1 Expert
Peter Taylor
