Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Whirlpool ET1MTMXKQ01 Freezer nor frig will not cool ,lights on,top freezer fan on,and bottom fan both running when plugged in.
  • girl28 Jun 12, 2008
    2 days ago my fridge gradually started getting warm. The food in the freezer became soft and does not freeze but stays cold and chilly. The bottom part of the frigde everything is sweating and barely cold. I adjusted the temp to the highest it can go, but nothing is helping. I moved the fridge over last night and water came from underneath it. The light is on the fan is running. What the matter with my fridge?
  • 725 Answers
Is you compressor running? do you have heat in condensor check your the evaporator for a frost pattern..
let me know if you need help
Posted on Apr 05, 2008
Bottom of freezer freezing bottom of frig cooling top of freezer and top of frig not cooling or freezing
I'm thinking you have a Bad fan. Not circulating air? You should hear the fan running when you open the door.
Feb 13, 2018 | Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Frig on top freezer below.....freezer working.... frig not...condensor seems fine and fan is on?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 20, 2011 | Amana ABB2227DE Bottom Freezer...
The freezer keeps defrosting.....starts to cool down then back in defrost mode again. Also the bottom of the fridge is not keeping things cold anymore. Could you please help me on what could be...
the defrosting mode could a problem with the defroster timer. as for the bottom one if the top is not cooling the bottom one wont either. the freezer fan is what also keeps the bottom frig cool. the defrost timer should be on the bottom frig close to the ligth.
Jan 19, 2011 | Whirlpool ET8FTEXM Top Freezer...
Refrigerator is cold in the freezer, but the top of the frig is not cold. Is there are fan to cool the top part of the frig?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 05, 2010 | Amana ABB1927DE Bottom Freezer...
Frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Mar 29, 2010 | Whirlpool ET8GHMXLQ / ET8GHMXLT Top...
Freezer frozen on bottom and frige cold on bottom only. No airflow coming from vents inside freezer or top left of frige, freezer and frig warm at the top. Model is a ED25QF
check to see if fan is running in freezer if it is you may have a defrost problem if not replace the fan its the evaorator fan that is in the freezer
Mar 08, 2010 | Whirlpool ED5FTGX Side by Side...
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
Whirlpool refrigerator model#WRT-75680. Have
Assuming the freezer is adequately cool, it sounds like the freezer fan is not running. This fan transfers chilled air to the refrigerator section. The fan should be located behind an access plate in the freezer. If it's running, you should be able to hear it. If you can't hear it, remove the access plate and look at it. If it's not turning, you will need to replace the fan motor.
Oct 16, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
105 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
