Question about Sony KP-46WT510 46" Rear Projection HDTV
Ready to replace the STKs. Before digging in what points (caps etc) need to be shorted before servicing?
I've got the service manual, but wanted to check with you guys as well.
Thanks,
Puterbac
  • puterbac May 01, 2008
    Didn't really answer the question I asked.
    Anyway fuse was blown on Red Horizontal.
    Several weeks ago replaced both convergence ICs and fuse. Cleaned off old heat sink compound and put new on.
    Works fine. Actual replacement of parts only took about 25 minutes. Most anoying thing was making sure which cable went where before unplugging all 30+ of them.
    Sergeant:
    Champion:
  • 319 Answers
If you are not familiar with servicing electronic circuits, I would strongly suggest you did not try. You could do far more harm to your equipment and worse, to yourself, than it is worth. Please, take it to a professional for repair. The price could be a lot less in the long run
Posted on Apr 23, 2008
My TV monitor has developed a vertical blue bar approximately 4 inches wide from the right of center in the middle of the screen to the top. How do I fix this? Is it an adjustment or do I need service? ...
The unit does need service. where are you located ? I can point you in the right direction. It may be less expensive to replace the unit. what was its original cost?. I would have to do a little digging, but may find the answer and a relative cost for you. post a comment/reply on this question and I will try to help you further.
Jun 01, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Convergence
After replacing the stks you need to perform convergence adjusment procedure.
If Stk keeps burning out then replace convergence board.
Sep 03, 2008 | Sony KP-46WT500 46" Rear Projection...
How to adjust red blue colors
Replace both of your Convergence ICs STKs
Mats has them 1`-800-628-1118 Then you will need to know how to enter service menu.
May 14, 2010 | Panasonic PT-53TW53 53" Rear Projection...
My convergence won't fix the color problem. When trying to use the convergence ajustments on the tv, the red is ok but the blue won't realign. The blue is bowed from the bottom about 8 inches and slightly...
Check all the resistors that are connected to the stks especially the 3 that have same values, resolder if required. Also use a magnifing glass to check on embedded resistors on the soldering side of pcb. you may have unknowing desoldered one of them or caused shorting. These will be small ant size blackish rectangular resistors. most DIY people mess them up. Some tvs may have them too close to the stk terminals and require careful desoldering and soldering while replacing the stks. vote if it helps and thanks if you voted. check out www.fixurtvs.com
Apr 09, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Color rings and halos
Does it have magic focus? tried it not working? do full convergence adjustment using service mode as mentioned in service manual. Its better to download it from the tech support at this site and go step by step. There is also a blue button switch on the convergence of some models. If you cant adjust some colors with service mode, check resistore with STKs, if the colors are really bad it may be better to replace the stks also while you are at it. But do you have the skills to do it? check it out at www.fixurtvs.com. Thanks if you voted.
Mar 24, 2010 | Hitachi 51F500 51" Rear Projection...
I have a mitsubishi projection tv. I can't adjust the settings. I replaced the congergence chips. What else could it be Model VS-45605
Did you replace STKs with same as old STKs? STK392-570?
Do you know How to Enter Service Mode for Mitsubishi to make convergence alinement ?
Feb 07, 2010 | Televison & Video
Unit cuts out after short period.
Yes it could cost as much as $450.00.Your set Needs Both of the STKs replaced. Hope you can solder or get someone who can, STKs are convergence ics they also control power too! If you have in your set STK392-110s use the 180s 110s do not hold up They will be big black ICs
Dec 24, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Hc-p4752 black screen when powered on.
glad i could help ...now the black screen .. remove the back turn it on and look at the actual tubes
the base of the tubes should have a reddish glow if not the set isnt fully on look at the top of the tube if its on you should see a box or a dot etc
if both conditions above are true then you have damaged the stks you will need to replace them again
you can order from here $7.99 each http://www.electronix.com
remember to solder carefully stks do not take shorts well
if you dont see anything in the tubes you may have damaged the regulator too if you have a multimeter handy (and you know how to use it)while the set is running check (pins 15,18) for +28 volts {pins 16 ,17 and 19} for -28 volts if you dont get around those voltages you will be replacing the regulator too its probably an str (something or other) look around where the power cord plugs in for a big transistor looking thing..
good luck
Sep 21, 2008 | Samsung HC-P4752W 47" Rear Projection...
Picture is curved
Repalce Both STKs ICs may be using STK392-110s or 560-020 let me know which STKs you have so when you replace them you need to upgrade ics.diffenrent number if they are 110s go to 180s.
Sep 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
