Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Initial setup The "Initial Setup" auto program screen keeps flashing on and off intermittantly, more and more frequently, no matter what you try to do to stop it. I am having some the same identical problems the guys are with their Sony 32 inch tvs where the initial setup pops up. Try to change channels and you can't with the remote. Video 1 displays. Just a true pain.
  • Anonymous Mar 22, 2014
    a message that says sony initial setup autoprogram
    Genius:
  • Sony Master
  • 1,646 Answers
This is commonly caused by the CRT going too weak, and the AKG circuits are switching off the bias to the CRT. This is part of the high voltage regulation protection.
Other causes, but are rare to cause this, are failures in the bias circuits, high voltage regulation (flyback assembly), and in the scan amplifiers.
With proper experience, reference to the service manual, and the proper set-up, it is possible to determine the causes of the failure, and service it. The cost of the parts will be rather expensive if you can still have access to them.
Jerry G.
Posted on Jul 12, 2008
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Service engine error 181.514
Service Engine Error 181.2049 Maint failed to prime back pressure
This error most frequently happens during the initial printer setup. Another reason for this error to occur is when using malfunctioning cartridges or cartridges that do not have enough ink to complete the initial setup of the printer.
Inserting a new set of setup cartridges or by using the setup cartridges provided with the machine would resolve this issue. To identify whether you are using the setup cartridges.
If you are already using the new setup cartridges, unplug the power adapter from the back of the printer and re-plug it after five seconds and let the machine attempt a second initial setup.
Jul 26, 2014 | Lexmark OfficeEdge Pro 5500 Inkjet...
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Initial Setup Screen
Have you ever cleaned the set front glass with windex or glass cleaner.Sometimes the fluid runs down before you can wipe and lands inside right on top of the push buttons that control ( CH,VOL, MENU, etc.) If this happens you can get this trouble. If you up to it take the cover off and look at the board just under the front edge of the crt. If you see green or grey residue you probably have to remove that corresponding TAC switch. You can just cut out and use the remote for that function.
Apr 07, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
KV-36FS200 WEGA Initial Setup Annoyance
hello my friends i beleive that you have some loose connections on the main board around the eprom
good luck
caypianan@yahoo.com
Aug 20, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Changing the time on my Motorola Razr V3 phone
Go to settings
--> Initial Setup
--> Time and date
--> Auto update off
Then you will find the time and date.
go to date use right soft key and change the date and similarly for the time.
Jul 28, 2008 | Motorola Mobility RAZR V3
Initial Setup flashing on and off
1) Do a hard reset = leave unplugged for 12-24 hrs , then
try again.......................................
2) What does "until the remote is disabled" mean ??
Nov 09, 2007 | Sony KV-32V16 TV
Initial setup
First give it a hard reset. To do this you must unplug the power cord for at least 4 hours; then try again.  This will reset the internal programming and restore it to factory defaults settings. Unplugging for a shorter period of time may not do the trick.
If the hard reset does not solve the problem it has a defective eeprom OR a bad voltage regulator that feeds the controller IC/eeprom set.  In which case you will need a tv tech to dignose the exact fault and determine the defective parts. (There are over 100 parts associated with these functions).
Hope this helps.
Oct 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Heh. I just gave my set the "Fonzie treatment" after I was convinced the initial setup notice was messing with me. The problem cleared right up. No joke.
May 30, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
176 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
