Question about GE JGBP28 Gas Kitchen Range
Oven Temperature Sensor
How do I check and/or change the oven temperature sensor on GE JGBP28 Gas Range?
  • Anonymous Mar 14, 2014
    location of oven temperature sensor
    Habit-Forming:
  • 171 Answers
It's just not just the sensor ,it's the thermostat which is on the back of oven knob. that sensor is part of the thermostat it's all one of the same part. to check the temperature put a thermometer inside the oven and set the the oven knob at 200 degrees. 20 minutes later check and see what temperature it's inside the oven, to regulate the temperature many of the new ovens are set from the factory, It can not be calibrate, on the older ones the adjustment screw is inside the shaft when you take the oven knob of, it's inside the shaft.
Posted on Dec 07, 2008
Hi i own a tappan tgf328 gas range and I'm trying to heat up the oven and its beeping and giving me an F31 code. Can you help me?
Tamppan Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Apr 07, 2011 | Tappan TGF320 Gas Kitchen Range
JGBP33 Get an F2 Error, oven gets warm but not hot enough to cook, will cook on broiler mode? Any help would appreciated.
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F
Look for welded relay contacts. If this happens, replace oven control (also
If no over temperature condition occurred:
Look for a high resistance connection or any other cause of high resistance in
the oven temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
defective. Check door lock switches.
measures resistance of sensor circuit , not actual oven
temperature.
Feb 06, 2011 | GE JGBP33SEHSS Stainless Steel Gas Kitchen...
When using the oven the error code F2 comes on. What does this mean and how do I get it fixed?
F2
During
occurred
found defective.
During
915F-930F If actual over temperature condition
occurred
: Look for welded relay contacts. If this happens, replace oven
occurred
found defective. Check door lock switches.
(ERC) measures resistance of sensor circuit , not actual oven
temperature.
Dec 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
F2code
This means the oven controller sensed an over-temperature condition. This could be caused by a faulty temperature sensor, a cooling fan problem, or a problem with the oven controller itself. If it turns out to be the latter, we repair these at www.fixyourboard.com.
Oct 10, 2009 | GE JGBP28 Gas Kitchen Range
F2 Error when using the oven GE XL44 Gas Range
Control senses oven temperature above 615F-630F
If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Jul 23, 2009 | GE Spectra JGBP35 Gas Kitchen Range
F3 code on ge xl 44 gas range
F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact
Jun 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F-3 code on GE gas range
Hi, You may have a Open or shorted oven temperature sensor (RTD) that should be replaced.
Please rate and have a great day:)
May 18, 2009 | GE Kitchen Ranges
Fault code F3, then F2
Well here's the details about those codes:
F2 :-
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
F3:-
Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor
Apr 04, 2008 | GE JGBP28 Gas Kitchen Range
F1 fault
Here are the fault code for GE:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Nov 07, 2007 | GE JSP26 Electric Kitchen Range
GE JGBP28 Gas Kitchen Range Logo
288 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
