Question about Dishwashers
Leaking dishwasher .leak coming from underneath of dishwasher
  • 1 more comment
  • Anonymous Aug 05, 2008
    I am having the very same problem. Have removed the cover at the base and watched it (carefully) cycle and it is most definitely coming from the part that moves (actuator?) when the unit drains the washer. Any advise on replacement? I am willing to do it myself if advised. Suggestions?
  • Anonymous Sep 23, 2008
    We found it to be a crack in the actual bottom of the plastic tub. We've done epoxy, and tried to fix it several times as it's out of warranty (of course). Started leaking again this morning, and my husband says there's just no fix to it. After all, how does one go about welding a plastic piece? ha ha Frustrating!
  • Anonymous Oct 31, 2008
    I have had my danby DDW396W for 2 1/2 years now and it just started leaking from the bottom, on the right side. My warranty expired after a year. I tried calling a local appliance fixing store but they said it would be $60 just to look at it. I tried opening up the unit to see what was going on at the bottom of it and it does look like it has been leaking as there is a lot of rust under the main motor but i couldn't open it up enough to really see where the problem was. it is still washing dishes but last time i used it it was leaking like a lake and soaked a full bath towel in no time. i'm not sure what to do; i really like my countertop d/w and don't have room for a full sized one; do i buy another danby and just junk this one or is there something i can do about the leak?
Mine is leaking underneath too.  it looks like the water is coming from the actuator that allows the drain to open.  in fact, it is only leaking when the actuator opens the drain.
Posted on Aug 03, 2008
My dishwasher has leaked a smal amount of water from underneath
Jackie, It is probably a seal(gasket) leaking, you may want a service tech. to have a look.
Mar 09, 2016 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher leaks
Hello - Since you have previously replaced the bottom gasket and issue continues I suggest contacting a professional to move forward accurately. The leak could possibly be coming from the drain motor/pump or a loose hose connection located underneath.
Oct 03, 2012 | Frigidaire Professional Series 24 in....
Water leaking out from underneath
How to Fix a Leaking Dishwasher Hose. *. Whirlpool Dishwasher Connection ... the drain hose pushes water from the dishwasher without water buildup ...www.ehow.com/how_12089937_fix-whirlpool-dishwasher-leaks-underneath.html
hope this will help
Jan 31, 2012 | Whirlpool Dishwashers
WATER IS LEAKING FROM THE BOTTOM. IT'S COMING FROM FROM THE PUMP.
This is repaired by pulling the unit out and working from the rear and underneath, check for the leak, either replace the pump or gasket or hose, depending on where the leak is coming from. You may need some star screwdriver type tool.
Mar 24, 2010 | Maytag MDB7100AWB Dishwasher
Waterleak
is it leaking from the door or from underneath it. If it leaks from the door then you need a new seal. If it is leaking from underneath it could be the waterline coming into the dishwasher or the drain hose. Both fittings are underneath the dishwasher and are accessible through the lower panel on the face. Let me know if you can figure out where the leak is coming from and I will help you solve the problem.
Thx
Jul 31, 2009 | Dishwashers
Danby dishwasher leaking from underneath
It is still under warantee-contact the company you bought it from. If you fix it yourself you could void the warantee.
Jun 14, 2009 | Danby 22 in. DDW399 Free-standing...
Plumbing connection to dishwasher leaking
Remove bottom panel and run dishwasher while monitoring it. A large leak may be from a hose off at pump underneath. Mice can chew holes in hoses too.
Nov 15, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dishwashers Logo
1,111 people viewed this question
Top Dishwashers Experts
