Question about Zhone (6218-I2-200) Router
Port Forwading How do I port fowarding in this router. I want to serve up a Java Web Page Port 80 Port 3011 Port 47808
  • sfDakota Apr 07, 2008
    The real problem is they do not have a Public IP
    Sergeant:
    Champion:
  • 427 Answers
Go to your routers setup page,
Go to the section labeled port range forwarding, then enter the information.
Posted on Apr 04, 2008
Port Forwading
pls try disable the DMZ in router it will forword all the TCP ports to your designated host in your internal network
pls Note that, it will course disable sequrity in your designated host as well
Apr 15, 2013 | Computers & Internet
Am trying to set up a Windows 2003 server to serve web pages over the Internet. Have got a DSL line from Embarq. They installed a EQ-660R interface which is really build by Zyxel. I can reach the Internet...
In order to access your default web page remotely, port 80 "INBOUND" must be open to the internet.
To access your web server, two things need to happen.
The first is you or someone else must initiate a http request on port 80 using the public IP Address of your DSL connection.
Second, your router must forward that request to your servers internal ip address.
Ex. Lets say your public ip address is 24.39.45.10. In a browser window from a remote location, you enter the URL http ://24.39.45.10 The request will be sent to your router on port 80.
Your web server will not have the ip address 24.39.45.10 because it's on the private network side of your router. So, lets say the private ip address of you server is 192.168.1.100
You need to configure your router to take the http request coming from the internet on port 80 to ip address 24.39.45.10 and forward that request to 192.168.1.100. This is known as port forwarding.
You also need to configure the host header name of your "web page" so it knows it needs to display the web page.
Since we're just using ip addresses in this example and not an actual FQDN (fully qualified domain name), you would make a host header entry for the web page of 24.39.45.10.
To do this open IIS.
Navigate to the web site in question and right click on it then select properties.
On the website tab, ensure the port number is set to 80 and choose the appropriate internal ip address if you have more than one network adapter in the server.
Next click on the advanced tab and look for the heading Multiple identities for this site. This is where you enter the ip address 24.39.45.10.
If you have a fully qualified domain name, you would enter the domain name instead of the ip address as specified in this example.
Host header names are the key to running multiple websites from one physical server as long as it has the necessary horsepower to do so.
Hope this helps and isn't confising. If you're confused in any way, don't hesitate to ask for clarification.
Sep 13, 2009 | Zyxel P-660RU-T1 ADSL Ethernet/USB Router...
How to create a port on my router
please follow the steps are given below,
1.Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
Krishan
May 09, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Port forwading
http://portforward.com/
this site may be of some assistance
Jun 19, 2008 | Computers & Internet
Configure with utorrent
1.) To set up a static Ip address on your computer, click start, control panel, network and internet connections, network connections, right-click on local area network, click properties. In the window select tcp/ip, then click on the properties button.
Since your default gateway address is 192.168.2.1. Click on the selection titled 'Use the following ip address' Your Ip address should be 192.168.2.2, subnet mask 255.255.255.0, default gateway 192.168.2.1. Then in the next section click on the selection titled 'Use the following DNS server addresses' Preferred DNS would be 192.168.2.100 and alternate would be 192.168.2.200. click ok and you are done.
2.) As for the second problem, refer to the following link from the intellinet website. http://portforward.com/help/pfprogression.htm
Mar 05, 2008 | Intellinet Active Networking Intellinet...
Port Fowarding
Here is a listing of programs and how to forward them for your router.
PortForward
Feb 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Curtis
Run NAT on your router
then lets say your LAN (router) 192.168.10.1
and your pc (webrouter) 192.168.10.100
then use Port Forwarding on the router to:
Foward port 80 (www) to 192.168.10.100
fins
Jan 09, 2008 | Netopia 3347W-KIT ADSL Wireless Gateway,...
Optimizing WGR614(v1) for xbox live
the normal port that requires opening in your router for xbox is TCP3074, you should just type the number in as if there are no options, although there should be, it may know that 3074 is a TCP port.
Sep 28, 2007 | NetGear WGR614 Wireless Router
Router problems
Did you validate the IP addresses for each computer? Issue the "ipconfig" command on each and compare the IP addresses. You may have a conflict. I would clear any port forwarding settings first
Jul 29, 2007 | Belkin (F5D5231-4) Router
Zhone (6218-I2-200) Router Logo
375 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
