Question about Car Audio & Video
A Dual car cd player'' remote wire ''blue''
I't wont turn on my amp when i turn on the car. i have do to connect it to the red wire for it to turn on but not just but u could hear the car engine on the 12'' JL audio.
  • 185 Answers
Run ur remote wire to the head unit from the amp its blue and u said the head unit u have is a duel it should have a yellow wire or or a dark blue one. hook up the remote wire to one of those and let me know if that works and one more thing do not run the RCA cables on the same side of the car or truck what ever u have but if ur power wire and the remote wire are on the left hand side run ur RCA'S on right from the head unit to the amp.
Posted on Apr 05, 2008
On alpine cd3 9852 model, attached wiring for model of car and proper connections, yet subs only work for radio.subs will not work for CD or IPod connection.all wiring is color coated and has been checked...
Make sure you are using the blue/white wire to turn the amp on. The blue wire is antenna remote and turns off when leaving tuner mode. The blue/white wire is amp remote turn on.
Sep 15, 2011 | Alpine CDE-9852 CD Player
Need wire diagram 4 kenwood kdc-122
Red wire is switched power (only has power when key is turned), yellow is constant power, black is ground, blue is accessories (e.q. or amp switched power), dual grey, dual blue, dual white and dual other is for speakers, (usually the one with the marking is the positive speaker side). This should help..
Jan 31, 2010 | Kenwood KDC-122 CD Player
The woofer wont turn off
The only wires that should be going to the subs are the Speaker wire, The power, goes to the amp, Blue the remote wire should only go to the remote spot on the amp wich is usually labeled rem. and the ground all goes to the amp.
Nov 19, 2009 | Vibe CBR10 Car Subwoofer
There are red, yellow, and orange wires with fuses. do these all connect to the power? There is also 1 blue speaker wire. it looks to be coupled with the orange? could that be true?
the red is for key power(gives power to it when you turn the key on) yellow is for memory power all the time keeps clock and progremed challels bule and orange are for the amp blue turn amp on when the radio is powered up
Oct 03, 2009 | Dual CDM180 CD Player
What colour are the power wires, are they green & yellow, black, black & grey, blue & grey, red & grey or black & green. I want to connect a cd/radio player but don't know what wires connect to the cd...
JVC KW-AVX800 The black wire is your ground The yellow is your positive 12v constant so connect this to the wire that has 12v when the car is off. The red connect this to the key switch wire meaning the wire will have a 12v signal only when the key is tured to the on position. The blue is for a power antenna the blue/white stripe is if you have external amps this wire goes to the amps remote on The orange/white stripe connect this wire to your cars dimmer switch Happy Wiring
Mar 21, 2009 | JVC KW-AVX800 CD Player
CD player wont come on was doing weird things
You have your accessory wire (red wire) and remote ran together and the yellow (constant wire ran separately in the dash?
You need the red wire to so you can use accessory and to turn off your cd player when your vehicle turns off.
You need the yellow wire to keep all your settings stored. base/treble/time clock
Just a little clarification. Your amp turns on with the remote wire (blue) wire, if that is not hooked up you will get no power to the amp.
Here's the in-dash diagram to your vehicle at the bottom of this pdf.
You want to focus on N,O, and P
Do you happen to have an after market wiring harness? These can be bought from walmart for your vehicle. You just take the male end connect the colors together and plug end that goes to your cd player into the female end. Very easy to do.
Windshield wiper issue: Check C1002, 1003, and 1004 under your hood.
You could also have one of these fuses out under your hood, that might cause you to lose power to everything.
Let me know if you need more assistance =)
Feb 01, 2009 | Kenwood KDC-MP238 CD Player
Cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
Jan 27, 2009 | Kenwood KDC-MP228 CD Player
Kenwood KVT-617DVD sound issues
the wireing off the brain is connected wrong, ok look at the wires and now disconnect your remote wire from the amp remote now connect the second blue wire to the remote wire going to the amp, now your sound should be right
Jan 21, 2008 | Kenwood KVT-617DVD Car DVD Player
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
Dec 25, 2007 | Alpine CDA-9807 CD Player
Pleae help me with my radio
Hi Ant81,
You should only have the Blue wire from the Dual connected the REmote terminal on the Jensen Amp. The Audio cables are the only other wires that connect from the Dual to the Jensen Amp.
Nov 25, 2007 | Dual XDM6830 CD Player
Car Audio & Video Logo
479 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
