Question about Logitech MX 1000 Laser Cordless Rechargeable USB Mouse 9311750215NR
Hang ups my mouse gets hung up a lot when going side to side or up and down. like its hitting an invisible wall. if i shake the mouse in a circle on the pad a few times then it works fine. this happens a lot. i have tried soft mouse pads as well as ht hard ones. neither was better than the other
    Top Expert:
  • Logitech Master
  • 54,153 Answers
Your mouse may be dirty.
Posted on Jan 25, 2018
SOURCE:
SOURCE: my mouse won't work properly
try new batterys
Posted on Jun 15, 2008
SOURCE: keys not working but mouse pad+volume+media keys all working
this happened to me once before i realized i just needed to re-sync the keyboard with the bluetooth dongle.
hope that helps.
Posted on Jan 10, 2009
  • 202 Answers
SOURCE: Logitech cordless mouse won't work right. Hard to stop in one
Have you connected the mouse and keyboard to the receiver? There is a button on the bottom of each marked "connect". Press and hold the button down and watch the light on the receiver. The blinking will change when the device is recognized. It should operate smoothly after that.
Let me know how it works out.
Posted on Feb 19, 2009
  • 67 Answers
SOURCE: I have a logitech cordless optical mouse which as stopped working
try this... unplug the USB and plug it back in,
& clean the laser window on botton of the mouse,
Posted on Apr 04, 2009
  • 223 Answers
SOURCE: mouse not working correctly
Your batteries could be getting low or your reciever could be too far away.
Posted on Jun 01, 2009
Why is my flex piping hunging low I hear it hit when I go over speed bumps and I also hear some kind of shaking noise when I hit a pump
Flex piping is not a permanent fix. as time goes it will start to flop as you hit bumps. You could try fastening it up or replace with the proper piping.
Jul 19, 2014 | Cars & Trucks
Bosch shu 9900
take the bottom front cover off and check that the springs for the hinges are not hung up on something. it sounds like that is the problem
Apr 08, 2014 | Dishwashers
Trying to mount a heavy piece of flat art on the wall, aproximately 72" x 48" and weighing 200 pounds. Trying to find a compatible hanging system
You need to know what the wall is made of - brick, block, concrete, plaster board, etc? Then go to a DIY store and ask - they'll advise you. If its an internal plaster-board wall then I doubt it will be strong enough. A while ago I hung a 4' x 3'6" mirror on a block wall using two fairly heavy duty rawl bolts and its still hanging.
Mar 06, 2012 | Televison & Video
I want to hang the dryer on the wall. Can I hang it upside so I can reach the controls?
No you can not hang it upside down without a re-design of the rear bulkhead. The drum rollers are on the bottm of the drum. If you hung it up side down the drum would drag on the top part of the chassis.
Kelly
Jan 22, 2011 | Miele Novotronic T220 Electric Dryer
I need to delete currupted data on my ps2 memory card
Plug in the PS2 memory card and dont put in a disk,and hit the power button once,like you would to start the machine.Then a screen with flying orbs(or cubes I cannot remember)should show up in the backround.Then hit the X button to enter the next menu.It should show your memory card,or two if you have two in.Select the memory card and hit X.After that it will dive into the files.Go to the memory that is corrupt and hit X,then find the delete function and hit X again.The memorys icon should fly in circles and get smaller,like its getting flushed down a invisible toilet.If you do not know the corrupted data,you may have to go through and delete memory untill you find the corrupted file.Also corrupted data can interfere with gameplay and make it impossilbe to load some games.I hope it helped.
Dec 17, 2009 | Sony PlayStation 2 (PS2) Console
Turns in circles, acts like it hits a virtual wall then stops
Reboot is probably not your solution. Your Roomba will react to invisible signals or 'interference' from other electrical appliances as well as the invisible wall boxes. You can clearly see how this happens when a Roomba gets near your computer or other device that is on. Also, the Roomba will go in circles when the dirt chamber is full or it thinks it's full. Try a thorough clean of all major parts including the brushes. Sometimes this activity will occur when the brushes get snarled on thread or carpet fibers.
Oct 09, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Green mushroom house world 7
This is hard, but not impossible. lol if you are a good "wall jumper" than it's a piece of cake. You will need to be miniature Mario for this. the easiest way to be miniature mario is to go back to world 1 and level four. In that particular level there's a question mark square that has the little blue mushroom, just finish that level in miniature "mode" and go back to world 7. Why little Marion? Because little mario can jump a lot higher than any other mario can. Now, in the ghost house, right after level 1, is where you'll get the pathway to the mushroom. hit the first (and only the first, no need to worry about making mistakes and having to start over) solid brick and an orange button will appear, as you may already know. step on it (watch out for the little ghost thing) and five golden doors will appear. Enter the bottom right golden door and you'll enter a room with a bunch of white hands pointing to the location of an invisible square, but who cares?! ignore the hands and square and go straight to the jumping jack looking thing. Jump towards the right wall and "wall jump" your way to the golden door on the top. When you enter this part of the level there will be a bunch of golden coins and a blue button. Now this gets a bit tricky. hit the blue button and run immediately to the LEFT (you are short on time, so READ the entire thing first, so that you don't get lost) (not the right where you would usually go to) the bricks will form two "L"s the first one is facing the wrong way,(after passing it) an opening will be there where you will jump up and access them, stick to the LEFT "L" structure (or the L facing the correct way). Now, since you are running, you are going to have to jump up towards the wall (that's now there) "wall jump" to the RIGHT and you will SEE the golden door that you need, HOWEVER, one wall jump will not be enough and you are going to "wall jump" to the LEFT using the single square "platform" where the door is at. and when you get to the wall, you are going to have to "wall jump" to the RIGHT once more. (NOTE: if you run straight towards the wall and try to wall jump from all the way from the left, you will NOT make it, you need momentum that you can only get by running and jumping towards the wall) you will most likely over do it, but don't worry!!! slide down the wall that's above the door and just keep holding the right arrow on your controlling pad, mario will simply land on the platform without any effort. I understand that what I just said may not make a lot of sense, but once you see it, you'll know what i'm talking about. Don't get frustrated for this may take several tries. good luck.
PS if you don't know how to "wall jump" this will be very hard for you.... so get some time "wall jumping." you may already know this, but just in case....
HOW TO WALL JUMP: how do you wall jump...? well you hit jump as you hit the wall. If you can slide down a wall, you can "wall jump," all you do is basically hit the jump button and then point the arrow pad (left or right) to which ever side the wall is at. ex if the wall is on your left, you jump close to the wall and hit left on the arrow pad and jump. MArio, then. will jump to the other side off the spot you hit the controls off. you could even jump straight up slide down the wall and just hit jump.
Apr 12, 2009 | Nintendo New Super Mario Bros. for DS
New Super Mario Bros:Stuck on world 6
wow, I don't know how you guys got this far in the game if you can't wall jump... all you have to do is get on the red blocks and "wall jump" to the other side. how do you wall jump...? well you hit jump as you hit the wall. If you can slide down a wall, you can "wall jump" all you do is basically hit the jump button and the point the arrow pad (left or right) to which ever side the wall is at. ex if the wall is on your left (which is the case on this level) you jump close to the wall and hit left on the arrow pad and jump. MArio, then. will jump to the other side off the spot you hit the controls off. you could even jump straight up slide down the wall and just hit jump. Try practicing wall jumping, it'll make your life a lot simpler and the game much more fun :D good luck. you could twitter me if you have any questions, but twitter is kind of short with letters.
good luck to you all.
http://twitter.com/ilikeapples
Jan 27, 2009 | Nintendo New Super Mario Bros. for DS
I just bought a second hand westinghouse dryer 6kg LD605E, the sticker on the machine is upside down and the seller told me that the machine can be used either way. it this true? thanks
The LD605 series of driers is wall mountable and stackable
When wall mounting, the drier is hung 'upside down' with the knobs at the bottom to allow access, by people less than 8 feet tall.
The original package came with wall mounting bracke, and replacement sticker for the control panel with the text upside down so that it would be right way up when the dryer was hung.
If you arent going to hang the dryer, examine one small corner of the label area, the original label may be underneath and exposed by removing the wall hanging label.
The current model in the LD605 series still comes with wall mounting kit
http://www.westinghouse.com.au/product/display/model/LD605EB
Oct 11, 2008 | Dryers
Avaya Partner-18D office phone-After an intercom call, the receiver's phone rings
Try hitting the speaker button and intercom your boss. When you hit the speaker button to hang up, do you get the same thing? If not. It could be that the gray "clicker" switch that pushes down when you put the handset back isnt going all the way back down...
Let me know.
Dec 28, 2007 | Avaya 700340193 Corded Phone
Open Questions:
See all Logitech MX 1000 Laser Cordless Rechargeable USB Questions
Logitech MX 1000 Laser Cordless Rechargeable USB Mouse 9311750215NR Logo
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
