Sim-card rejected my sim-card are rejected. First it asked for a puk code and when I tried maser one given on this site now it is rejekting my sim card. Is there anything I could do to fix this problem
my sim card how locked i dont no ,so you solution given the my problem solved..in urgently...?my sim card how locked i dont no ,so you solution given the my problem solved..in urgently...?
You can't post conmments that contain an email address.
If the phone reject your sim card,there may be two problem with your phone.1)If you used incorrect puk code.The sim rejected message will appears after tries exceeded.The second reason for this,it is because of network lock.If your phone is locked to network,the sim get rejected by phone.So you need to unlock it.It is locked to which country's network.You can unlock it using the Unlock code.Visit the site Mobileunlocksolutions.com get unlock code for mobile phone and unlock it then use any GSM network sim card.You can get remote unlocking service for Iphone from this site and unlock.
This is a usual problem which occurs when an incorrect code is entered multiple times , when the phone is requesting for a PUK code,and eventtually the SIM card getls blocked after multiple incorrect codes or gets rejected.
May people are not aware from where can they get this PUK code,
The PUK code is provided by the SIM card's service provider , for instance , if your SIM card belongs to vodafone , then you need to call up vodafone customer service or helpline number and they will give you the PUk code after a usual ID check.
I would also like to inform you that people usually ask for a PUK code when their SIM card is locked and it's requesting a PUK code so they use their friend's cell phone to call up the customer care asking for help , however you can get the PUK code on the very day when you bring a new SIM card by asking the relevant executive in the service provider's gallery or calling up customer care.
Now all you need to do is get a new sim card , and ask for the PUK code to the service provider so that you can keep it stored to avoid future mishaps.
Hope this helps ...:) Your feed back would be appreciated.
PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software. Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone.
IF you put PUK code many times depending on the model it wil lock the sim card. This is because to prevent unathorised person using your SIM card.
Default PIN code for nokia mobile is 0000
PUK code will be given by the service provider only.
Please call your service provider or go to service provider office,they will assist you in this issue.And they will have a security check like name,Phone number and other information to check weather the SIM card belongs to you only.Then they will assit you.
PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software. Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too.http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
The PUK (pin unlock key) code is usually printed on the Back of the SIM pack check it out and if it isn't there then u need to call your carrier and they will give to to you after verification. Make sure not to enter the PUK code your self after 10 incorrect attempts the Sim will be permanently blocked and then u'll need to get a new one! For More Details Please Visit The Site http://www.keywordarticles.org
HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim. Contact your sim customer care department over phone.
Pin Rejected or Sim Card Rejected ?
Of course sim card rejected otherwise you would have blocked the pin code and phone would have asked you the PUK code already but anyway !
Sim Card Rejected !
Options - There is a free unlocker
Click the link to download but you should have special cable !
It is called DKU-5
You do not have one or you could not manage to unlock ?
ngxhghghdhghhgdgh
