Question about Bernina Virtuosa 150
Timing for Bernina Virtuosa 153
Bobbin thread will not catch. I have tried changing needles, cleaning etc. If I move the needle down it works for a few stitches but they look terrible. Can you give me timing instructions for my machine?
  • 2 more comments
  • San16 Jun 04, 2008
    Hi!  I have a Virtuosa 150.  When I sew the bobbin thread isn't catching.  It will catch then skip the next few stitches then catch, etc.  I have clean the bobbing casing, changed needles, rewound the bobbin and everything else I can think of but it still won't sew properly?  Help!
    Sandi
  • Missangip Jun 20, 2008
    Thanks so much Rick and let me tell you, you were so right! We tried to fix it our selves with timing instructions from another member and ended up breaking the head off a screw. We had to send it back to Bernina for repair which cost $300! Thanks for your help!
  • Anonymous Mar 12, 2014
    needle bar and hook are out of time.whats the height of bar at down stroke?
  • Anonymous Mar 26, 2014
    The instruction manual does not give these instructions
  • 202 Answers
Timing these machines gets pretty involved such as in just removing the covers. You need a grounding ******** your wrist as the cables all need to be unplugged and you don't want to send a static charge from yourself to the circuit boards. They are expensive. Then you need special sized metal pins to pin several pinning points so the needle, hook, stepping motors and feed dogs all co-ordinate with each other. Also several places need certain guages to set less than .1 millimeter size distances between different places to avoid other problems. You also need several sized torx screwdrivers and the knowledge to adjust the upper and lower tensions. The upper tension alone has at least 3 or four places that need to be in the correct position.
All of the above has to be done in a certain order also.
Its complicated enough. If someone is going to walk you through this over the phone expect it to be complicated. Even if you had a copy of the manual (which could be a copywrite infringment on newer machines) you can expect it to be difficult.
My advice is to leave it to the professionals to have it done right.
Posted on Jun 20, 2008
Bobbin thread tangling into knots on my Bernina QE 153
Its possible, refer to your machine manual to adjust the tension. You might need to change your needle to fit the thread you are using.
Feb 01, 2013 | Bernina Virtuosa 150
Some one said if you use a different needle will damage the hook what is a hook i use a different needle for awhile how can you tell if you damage the hook i got a bernina 153 QE from a friend work good...
The hook is in the bobbin area and is what takes the thread from the needle to make the stitch. A standard 15x1 needle or 705 needle is the correct needle for your machine. They are available at ant sewing center.
May 06, 2010 | Bernina Virtuosa 150
This is the first time I am using this machine... it worked for a little while (15 minutes)and then the needle jammed. The whole part that moves the needle up and down doesn't move, manually or by pedal. I...
Unscrew the needle and you should be able to move the balance wheel, take the needle out and then look for thread jammed in the bobbin case area.
Mar 03, 2010 | Bernina Virtuosa 150
The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Nov 18, 2008 | Bernina Virtuosa 160
Not catching stitches / bobbin correctly
When you broke the needle I think you have moved the shaft that brings the needle down ,you can adjust it !
Oct 05, 2008 | Bernina Bernette Deco 600
First the simple solution. Make sure your needle is inserted flat side to the back and all the way up.
The only other thing I can think of is that your hook is out of time and this will take a technician to re-time it. You may need to take it in for a servicing.
Jun 28, 2008 | Bernina Virtuosa 160
Needle hits the plate
Remove your needle plate, clean around it, turn the handwheel to see if the hook will catch your thread(Like you are trying to bring up the bobbin thread). If it catches okay, put the plate back on and as you tighten the screw push the plate towards the rear of the machine. Reassemble everything, rethread , insert a bobbin and try it by turning the handwheel again. If it still hits, you need a service. If it doesn't, have fun!!
ssewman7
Jun 07, 2008 | Bernina Virtuosa 160
Upper thread will not catch bobbin thread
Your machine is out of time. It would be best to have a tech adjust the timing.
Jun 01, 2008 | Bernina Virtuosa 150
Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Mar 02, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
914 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
