Question about HP OfficeJet 7310 All-In-One InkJet Printer
Printer Alignment problem
Any idea why all of a sudden this printer is only printing the top or bottom half of any text?
  • Anonymous May 30, 2008
    Only the top half of every two or three lines prints.
    Novelist:
  • 79 Answers
Hi .
I want to know in case the same thing happens while copy as well , in case yes , u can try to reset the printer to default settings again by following the steps below .
Perform a semi-full reset on the all-in-one by following the steps below
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
8 Allow the all-in-one to re-initialize. This may take a minute or two.
9 If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information
in case it copies fine in that case it can be an issue with the driver on the computer .
so for that you can browse the disc of printer n go to folder util > ccc > unistall > run the file uninstall L1 .bat file .
make sure you disconnect the usb cable . reboot the pc , insert the disc click add a device connect the cable when prompted .
Thanks n take care
hope this resolves the issue .
Posted on Jun 04, 2008
6ya staff
SOURCE:
Printing text at the same label in two directions
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Zebra TLP 2844-Z Thermal Label Printer
HP 950c printer is printing blurry. This started after changing the ink cartridges any idea what I can do it was not doing this before changing the cartridge and I have used servarl different cartridges.
HI ,
Hope somebody can help, my text is printing the top half of the script blurred but the bottom half is clear! My printer is a canon ip2600. I have newish cartridges and everything has been cleaned and aligned. Cheers
Apr 22, 2011 | HP DeskJet 950c InkJet Printer
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Lexmark C920 color print is faded on bottom of page
Quite possible something happened to the printheads.....especially the Magenta one. Might have been 'bumped' out of alignment. They might just need to be wiped clean with a toner cloth. They are usually right above the toner cartridges. Have you tried a color alignment adjustment in Config mode?
Mar 12, 2017 | Lexmark C920 Led Printer
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Alignment failure
open the access door at the top of the printer
Remove the ink cartridges
Put your finger in the upper left corner of the printhead ( inside)
you will feel a small latch rigth there push it upward
the printhead will loose and you may now remove the printhead
Thanks, PREM
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Lexmark Z53 Prints Lines
please clean wast toner tank it have under photocoductor
Mar 31, 2009 | Lexmark Z53 Color InkJet Printer
Bottom half of pgbk band doesn't print
First try doing a deep head cleaning or two; if that doesn't work, try removing the printhead and looking at the bottom of it to make sure there is nothing blocking the small ejection holes on printhead, reinstall the printhead, do the alignment again an that should do it, if not you may need a new printhead.
Aug 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
43 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
