Question about Lexmark E332n Laser Printer
Lexmark E332n Not Detecting OEM TONER
I have an E332n that is not detecting the oem toner, but will detect a 3rd party refurbished/recycled toner cartridge. Very strange problem. Any insight? THANKS IN ADVANCE
    Scholar:
  • 141 Answers
  • 25 Answers
First I would check the kill chip which is located underneath the toner cartridge when you hold it upside down it should be a small green or red circuit board about 1inch by 1/2 inch with either one single electronic component or several components on it now if any appear to be missing or coming off of the board then the printer will not see the cartridge this is a common problem with refurbished toner I recommend using OEM toner 50% (at least) of the lexmark printers that I see everyday are sent in for repair due to this problem. Lexmark put this on for product protection and it appears to be working pretty well which is what it is supposed to do
Posted on Aug 28, 2008
SOURCE:
How to replace Konica Minolta Page pro 1580 mf toner. please tell us
is the toner 3rd party or OEM. Replace with OEM cartridge. Well the toner is not the drum you bought a drum it needs toner. ????
go this site for operator manual
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 18, 2015 | Konica Minolta Office Equipment & Supplies
I have 2 clients has problem black toner cartridge not recanized in Toshiba copier e3540c
Is the toner cartridge 3rd party or OEM? Might clean the chip contacts with alchcol. remove oil from fingers also clean the contact that the chip touches in the machine if there are chips. Try OEM cartridges
Nov 17, 2015 | Toshiba Office Equipment & Supplies
What happened when my KM5035 Copier is unable to copy after refilling the toner?
Konica Minolta toner cartridge you DO NOT Refill!!! You buy new ones 3rd party or OEM recommend OEM, there are electronic chips on the cartridge that tell the copier if the cartridge is new or old putting a old cartridge in with new toner is still a old cartridge to the copier!!
Nov 17, 2015 | Office Equipment & Supplies
Konica minolta page pro 1580 mf toner low message.how to reset?
Replace toner cartridge or did you fill it your self, if there is a chip on the cartridge and you refill your self then the old cartridge is still old. Are you using 3rd party or OEM? replace with oem
Aug 02, 2015 | Konica Minolta PagePro Office Equipment &...
Just changed the toner, but keep getting a "check the toner cartrige" message. How can I get my copier going again?
did you replace with OEM or third party if 3rd party replace with OEM
Apr 27, 2015 | Office Equipment & Supplies
Minolta 4695 claiming the yellow toner is empty, but it's full??
using 3rd party toner or OEM. use OEM and replace the Image unit with OEM.
May 30, 2014 | Konica Minolta Magicolor 4695MF All-In-One...
My Lexmark x2670 says left ink cartridge incorrect so I got a new one and it still says incorrect...help
Check and make sure it is an OEM toner. If you are using a 3rd party toner you will have to try the OEM.
Aug 28, 2013 | Lexmark Office Equipment & Supplies
I bought a Comeatible toshiba toner from china, after insall the toner it works fine, after our toshiba service center personal done some change in the machine, now toner not detect, how to solve this isse
It may depend on the model of your Toshiba. Some use a chip to track the toner in the machine. I am not sure about Toshiba, but other vendors like Lexmark program their firmware to detect and disable 3rd party toners. If you just had a rep onsite it is possible that they updated the firmware and that is where your problem would likely lie. That or the chip on your cartridge failed prematurely and it just happened to happen just after the tech was onsite. I would try another cartridge you bought and if it does not work, call the repair center and ask them if they updated any firmware or software for your printer.
May 16, 2011 | Office Equipment & Supplies
We have a Canon iR 2270 and get the the Error message E000024-0001. What might the problem be? How do i solve it?
if e000024-0001 is comming plz clean the toner box in which magnet roll is runing then try you machine is not give this e000024-0001 singnal.
Dec 28, 2010 | Canon IMAGERUNNER 2230 Copier
Ir 3570 error e000024-0000
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
0000 The connection detection signal is absent
continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller
PCB.
0001 Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
When the disconnection of the wire used for
detecting the connection of the toner level sensor
has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop
cassette feeding).
has been detected for 12.5 min without
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
interruption.
Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
Jun 15, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Lexmark E332n Laser Printer Logo
203 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
