Philips Magnavox MWR10D6 DVD Recorder Logo
Posted on Apr 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Finalizing dvd I know to hit set up when the dvd goes in then i go to finalize but what do i do to actually start it finalizing???? I cant read any of the online manuals i dont have adobe Thanks Mike
Anonymous
Level 3:
  • Master 472 Answers
  • Posted on Apr 16, 2008
Anonymous
Master
Level 3:
Answers
472
Questions
Helped
190885
Points
1152
Once the disc is in the drive.
Press SETUP
Goto Disc Options Press OK
Select Finalize Press OK
Wait until it is finished.
I have a jvc dr-mv150bj. I am knew to recording on DVD. I used the dvd to record the super bowl. I forgot to finalize and I was using a portable LCD projector. I unpluged the dvd recorder and took it...
finalizing completes the process of recording so that the disk can be read to play. Yes, probably if power goes off, you'll loose the recording as the disk can finish.
Basically, the code written at the end of recording creates a sort of index so the player knows how to read it.
3helpful
I just bought the Hitachi DZ-MV550A NTSC camcorder and I cant get it to play on dvd player on the TV Can you please help me Thank you
you need to finalize the disc. With the recorded disc in, hit the "disc navigation" button and you will see a place to hit "finalize". Move cursor to "finalize" and then click "yes". You can only finalize a disc using the AC power source, it will not do it from your battery. You should then be able to play it on your dvd player.
Andy
2answers
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
2answers
Unit cant recoginze/ read a disk
Randy,
I had a dvd-r disc recorded from a Philips dvd recorder that had not yet been finalized when the Philips went bezerk and died. I replaced it with the Sony GX300 and just for an experiment, tried to finalize it in the Sony
It worked. Not to say that it has to work with only THIS combination of the 2 same dvd recorders or twisting the scenario around with the Sony doing the recording and the Philips doing the finalizing. I also have a Sony dvd/vcr recorder to compliment the GX300. I will have to record a disc on the GX300 and try to finalize it with the combo unit to see if it will do well as a back up.
Right now a disc that is not full yet (home movie from my kids birth) is reading "Disc Error" on the GX300. I may have to do it over or see if the combo unit will do the same finalizing as the GX300. It doesn't have the amount of features that the GX300 has but thats what you get with a combo unit vs. a stand alone recorder/player.
If you know someone with another recorder, try to finalize on it. If not , you could find someone on this sight that has a GX300 and mail the discs plus a smalll fee and have them mailed back. Or you could find a used one cheap at some store and return it if it doesn't finalize.
Good luck
Dave
[email protected]
21helpful
3answers
Philips Magnavox MWR10D6 DVD Recorder Finalize dvd
hit stop go to setup menu pops up scroll down to finalize and hit enter
Just purchased - no manual - how do you finalize DVDs so they will play on other DVD players?
Using your remote, hit the function button. Scroll down to setup and right to disc setting. Enter on disc setting. Next screen will show 3 settings. Scroll down to finalize and hit enter. It will ask if you're sure you want to finalize. Enter yes. Remember; once you enter yes, there is no going back.
WHAT DVD DISCS WILL PLAY ON THIS DVD PLAYER
Assuming you are not having an actual hardware problem with the DVD player or an incompatible format (e.g. HD video & non-HD player); you should know that when you write video to DVD-R or DVD+R discs, you have to 'finalize' the discs on the creating drive for them to be playable on a regular DVD player. (Note a finalized disc can no longer be written to. If the player can read DVD-Ram (and your creating drive can write to them), DVD-Ram discs do not need to be finalized.)
Finalizing
Hi I was just reading your problem I have the same I think problem but I got the Premeum
so if your problem is the same cant play DVD it just reads then comes up incorrect disc C104 I will let u know as soon as I see if its the same problem u have the same model no# as mine also so here is my e-address if u e-mail me I can get right back to u quickr ok [email protected] Best of Luck to u if it isnt the same problem as mine
FINALIZING ISSUE
Press FUNCTIONS button;  Select DISK INFORMATION; Select FINALIZE; YES; START; ENTER.
Finalizing vs. not finalizing a DVD-R. DVD-R vs. DVD-RAM?
on standard players. The write all the information that a standard player looks for to read the disk. Nothing is lost if you take the DVD out of the recorder without finalizing it. On a PC, you would tell the software to eject the disk. Later model hardware can usually reopen a disk after it has been finalized. Is this a typo? 'I know that the disc cannot be seen in a DVD player after being finalized'. It should read; I know that the disc can be seen in a DVD player after being finalized
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
