Question about Microwave Ovens
Microwave Ultrawave with Hood fan
I have an Elite Microwave Oven/Hood Fan Ultrawave, Manufactured by LG. My kitchen timer will not work on 20.00 minutes and show the error F4. Also my 5 speed fan will only work on 1 speed. Could both of these need a new oven temperature sensor? Thanks, Marjorie
  • 35 Answers
You are right. f4 means shorted oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Apr 04, 2008
SOURCE:
LG LMV1813 F4 error code
F4 means sensor open, You have to check the Humidity sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 31, 2017 | LG LMV1813ST Microwave Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Have a TE code showing on my kenmore elite microwave hood combo
At some place I saw that the TE error refers to the touch panel.
If you go to http://www.searspartsdirect.com/ and enter your full model number you can get parts list and buy parts and even get repair advice.
Link below shows how to replace a control panel on some model of microwave oven. In the video you will see a ribbon cable being removed. You might want to wipe the contacts of the ribbon with alcohol and put it back in to see if it helps with your problem.
F3 error Microwave oven control panel replacement
Sep 11, 2014 | Kenmore Microwave Ovens
Kenmore Elite Microwave oven 63792 doesn't heat - all lights, turntable, fan, etc. work just fine.
Most likely it would be a bad magnetron since the light, turntable, and vent fan are running.
Sep 10, 2013 | Kenmore Elite Microwave, Model...
GE microwave fan not turning off
hello,
what this means is that your oven has develop a partial contact from the wire which supply power to the fan of your oven
what you need to do to fix up your oven is to unscrew the oven then trace the wire down to the fan you will see two wire red and black or white either of this wire is touching the body of the oven this while the fan come up it self then make sure that all wire are well place on there position
thank you and good lock .
Jun 01, 2010 | General Electric Microwave Oven
MY MICROWAVE WILL NOT HEAT FOOD. EVERYTHIN ELSE WORKS (FAN WORKS, BUTTONS WORK, CLOCK, KITCHEN TIMER, ETC) CAN I FIX THIS?
you can take it into a local repair shop but it might cost more to repair it. Looks like you can replace the unit for 150 to 250 sears carries this brand.
Nov 06, 2009 | Goldstar MV-1526 Microwave Oven
The inside fan cover started peeling and broke, i can't use the oven and need help!
its the fan inside the oven cavity on top, its part # AP3671492 and is a G.E. part# called the Cover,Stirrer Fan still manufactured
Sep 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
282 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
