Brother MfC 8820D model fax, copy machine combination: Feed can not work properly. Sometime it feed several pages in one time, sometime, it not feed paper at all. Please advises, Simon Lee 253-988-0313
  • 141 Answers
Normally by cleaning your pick-up roller and your stopper roller will correct your problem....Do that with alcool !
Posted on Apr 04, 2008
Brother MFC-3240C All-In-One InkJet Printer will not initiate when inserting a page to copy.
try cleaning the primary feed rollers with 99% alcohol. make sure mahine is unplugged and the rollers are dry prior to repluggin it in.
Feb 28, 2014 | Brother MFC-3240C All-In-One InkJet...
When a Brother MFC-8820D won't feed documents
I found this problem on a Brother MFC 8820D, but it may also apply to it's sister models: MFC 8420, DCP 8020, DCP 8025D, and DCP 8025DN.
Symptom: When you insert a document into the feeder to scan, fax, or copy, it recognizes it, but when you touch the Start key, it barely twitches, then says Check Original, as if it had jammed. You can pull the document out, touch Stop, and try again as often as you want, but it won't feed.
In my machine it turned out to be just a glitch in the memory. It cleared up with a Memory Clear operation:
You need to enter the Maintenance Mode. Here's the easy way on the MFC 8820D; other models may have different keyboards:
  • Turn power off.
  • Press and hold the Menu button.
  • Keep holding Menu down while turning the power on.
  • The machine appears to start normally. Keep holding the Menu button down until the words Please Wait disappear. Then release.
The word MAINTENANCE should appear on the display, while all lights flash in unison.
Maintenance Mode allows you to commit all kinds of crimes against your machine, all by entering just two little digits. Don't mess around - just clear your memory and get out. If you start to enter the wrong number, touch Stop, then enter the correct number.
The code for clearing your machine's memory is 91. That's it. You don't touch Start or Set or anything else - just the two digits. The 91 code initializes the EEPROM, but leaves your phone directory and your own name and number intact.
It will take a few seconds to clear everything, then return to MAINTENANCE. You have two ways to get out of Maintenance Mode: you can touch 99, or you can turn the machine off, then on again. Either way, it will go through it's entire warm-up routine. When it's done it should be fine again.
A similar problem can occur if a gear falls off one of the document feed roller shafts under the rear top cover. That's a different problem altogether.
on Aug 13, 2010 | Brother MFC 8820D All-In-One Laser Printer
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Brother copier paper feed grabs 2-5 sheets at a
check the feeed rollers ateh seperation roller the one that seperates the pages is worn.. it has proberly worn the tread and if its sn=mooth or worn it wont stop multi feed
Jul 29, 2009 | Office Equipment & Supplies
Brother MFC-8820D Prints a COmpletely Black Page
You have a defective or disconnected SCANNER BLOCK
Mar 06, 2009 | Brother MFC 420CN All-In-One InkJet...
Unit says Doc feed open. After checking many times it appears closed but can't clear the message and swith from fax to copy
raise the lid and hold the black pin down, located on the left back underside of the lid. your left hinge is probably broken or cracked causing the lid not to go down all the way.
May 26, 2008 | Brother MFC 8820D All-In-One Laser Printer
Our problem is not solved. It was suggested the feeder needed cleaning or wasn't working. The feeder works as we make copies of documents. If one is scanning can you feed the document or can you only scan one page at a time by placing it on the window?
Feb 13, 2008 | Brother Office Equipment & Supplies
Document to memory before sending
Here's the manual. Look at page 6-8. That tells how to turn on real-time transmission. You just need to do the same thing, except switch it to off when you get to that step.
Sep 06, 2007 | Brother MFC-8220 Fax
169 people viewed this question
