It's hard ware problem use lens cleaner it clean u r lens. after that same problem continue u change heads it's cost equals to new dvd player , ur's kishore chowdary.
Have you configured the two disk-drives to "mirror" each other, i.e., write every block of data to both disk-drives? If so, then one of the two disk-drives has "failed" -- it is not recording the data,
and all your data is _only_ available from the _one_ disk-drive. So, you need to identify which of the two disk-drives has failed, and you need to buy a replacement disk-drive. Then, use the "mirroring" software to copy everything from the "good" disk-drive to the "new" disk-drive, to re-establish the "mirroring". Do this before your _second_ disk-drive _also_ fails!
An external data-storage device has a few parts:
* a USB cable
* an enclosure
* a disk-drive, exactly as used inside a desktop or a laptop
* a USB-to-disk-drive adapter
So, if you open the enclosure, you can see an "internal" disk-drive.
You could even disconnect the disk-drive, and then connect a much-larger disk-drive,
in order to increase the capacity of the device (and to replace an out-of-warranty disk-drive
by a new in-warranty disk-drive).
One way:
* remove the disk-drive from your computer
* install a different disk-drive (any old, 4GB or larger, disk-drive will work)
* install Windows onto that disk
* install anti-virus software onto that disk
* reconnect the previous disk-drive as a "slave" disk-drive
* launch the anti-virus software, targetting that "slave" disk-drive
* shutdown
* disconnect the different disk-drive
* boot from the original disk-drive, now that it is virus-free
Review the safety considerations before performing the steps listed below by clicking on the following link:
CAUTION:
Failure to comply with the precautions
could result in damage to your product or loss of data.
CAUTION:
Observe all precautions when removing and replacing components.
Remove the battery, switch cover, keyboard, and palm rest.
Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
Use the black Mylar tab located on the
hard disk drive enclosure to slide the hard disk drive away from the
hard disk drive connector on the system board.
Remove the hard disk drive from the hard disk drive bay.
Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
1. Remove the hard disk drive from the electrostatic dissipating bag.
Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
the hard disk drive enclosure to slide the hard disk drive securely onto
the system board connector.
Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Try connecting the external hard-drive to a different computer. If it still fails, and it is still under warranty, then exercise the warranty to get it replaced.
If the warranty has expired, open the case, and remove the disk-drive, disconnecting it from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some desktop computer, to see if the disk is recognized.
If it is, then the USB-to-disk-drive adapter has failed, and you could go to any computer-store to buy a new external case and adapter, and mount your disk-drive inside the new case, and work with your files.
If the disk-drive is not recognized, check the warranty on the disk-drive itself.
Try connecting the drive to a different computer, to see if your computer is the problem.
If necessary, open the external case, and separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a "slave" disk-drive in some computer, to see if the disk-drive itself still can be accessed.
If not, and you have "important" data on the disk-drive, search the Internet for a professional "Data Recovery Service" -- you ship your disk-drive to them, pay them a lot of money, and they repair the disk-drive, just long-enough to copy your files to a brand-new disk-drive.
Your computer's motherboard has queried the disk-drive in your computer as to the "health" of the disk-drive, and the disk-drive is detecting that it is about to FAIL. So, ASAP, copy all your files to an external disk-drive, before the disk-drive DOES fail.
Buy a new disk-drive, attach it, and use something like NORTON GHOST or SYMANTEC PARTITION MAGIC to "clone" your old disk to the new disk-drive.
Yes, that is the total amount of hard drive space. This server was built for speed not for storage.
The xSeries 220 server supports four SCSI hard disk drives. The server does not support IDE hard disk drives. Some models support hot-swap hard disk drives and other models support only non-hot-swap hard disk drives. Your server supports four 1-inch (26 mm) slim, 3.5-inch SCSI hard disk drives in the hard disk drive bays. You can install four non-hot-swap hard disk drives in the models that have the standard non-hot-swap drive cage. You can install three hot-swap hard disk drives and one on-hot-swap hard disk drive in the models that come with the hot-swap drive cage. Both the non-hot-swap and hot-swap drive cages hold a maximum of three hard disk drives.
The calculation at that time was 4 drives with 36.7GB storage. Even if you find the drives somewhere, they will be very pricy.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
