Question about Vacuums
I got an new durabarnd canister with retractable cord vacuum cleaner 1 month back.One day when I was usinfg it, it just gave me a chirp sound and went off.Since then When I try to plug it in, it doest not start.I need a solution for it.Please advise
Buy a new one u tight **** we now live in a throw away world not many things these days are fixable things are exspecially designed so me throw them =away and go buy a new one
Posted on Apr 06, 2008
SOURCE:
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
I can't return my electric line. How can i fix it? I push the bottom to return my line, but no any action.
Hi there, it's Jack at Dyson.
DC47's cord reel button needs to be pressed down firmly to retract the cord - you should feel a click from the button when it's pressed down far enough. Keep hold of the plug as you press the button down, and allow the cord to feed back into the machine.
If you're sure you've pressed the button down as far as it will go, and have not been able to get the cord to retract, please get in touch with us directly so we can provide further assistance. You can reach the Dyson customer Helpline on 0800 298 0298 (UK) or 1-866-693-9766 (US).
Jan 23, 2014 | Dyson DC47 Animal Canister Vacuum Cleaner
Dear Technician, I have a problem with my cord to retract back in the canister vac. Would you please help with this problem solution. ...
Try tilting the vacuum so the front is at about a 75-90 degree angle to the back. Gently tug and release cord. This will usually retract the cord.
Jan 20, 2011 | Electrolux Lux 5500 Canister Vacuum
Power cord worn out where it enters motor, have to move cord certain direction and will turn on. Cord finally gave out one day and almost shocked me when it literally blew out. wont turn back on
You have popped the fuse in the plug top or have burnt out the wires in the cable
No matter you have got to shorten and re-wire the cable into the cleaner or get a new lenght of flex and do the same thing.
Some are easy to re-wire some are a pain
Aug 27, 2009 | Filter Queen Majestic Canister Vacuum
The automatic cable rewind on my Morphy Richards pod vacuum cleaner keeps retracting. I'd rather it didn't work at all than be constantly pulling out the cord. Is there any way in to fix it or disable it?
Hi Not really. It means that the cord has been pulled roughly when its been plugged in and the retracter is getting weaker to hold the cord that has been pulled out. Generally though wipe the entire cord from the end of the machine with a dry cloth and some furniture polish. This will clean the cord and add some resistance to the retractor that could minimise the cord flowing back into the vacuum.
Jun 19, 2009 | Miele S251i Plus Bagged Canister Vacuum
How do i open canister for cord retract repair
There are four screws under the lid, and there are two additional screws under the face plate for the controls display. You'll need a thin, flat blade screw driver to "pop" the face plate off. The two additional screws that you are looking for are deeply recessed about the bracket-nozzle park.
Jun 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux model 1401
try a local vacumn repair center or web site
Feb 04, 2009 | Electrolux Lux 7000 Bagged Canister Vacuum
S3765
Returned the sweeper to Costco for a full refund and bought another.
Sep 08, 2008 | Hoover S3765-040 WindTunnel Bagless...
Retractable cord
I'm assuming that you have bought the new retractable cord assembly. If you have so, I believe the cord should retract going counter-clock wise (pulling it makes it spin clockwise).
Feb 22, 2007 | Kenmore 23613 Progressive PowerMate Bagged...
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
