Question about GoVideo DV2150 DVD Player/VCR
Keeps flashing "Bad disc".....
Have DVD/VCR (I know VCR's are dinosaurs!) combo and none of my DVD's will play.
Machine keeps flashing "Bad Disc". I bought some DVD's from an E-Bay seller and semi-accused him of selling me pirated DVD's....only to find that other consumers are having the same problem with this unit....my bad! I'll have to write the E-Bayer and apologize.
Changed password - didn't work. Changed Parental Setting to 7 - didn't work. Next option: S**T-Can the machine; or just play my dinosaur VCR (yes, I still have a few) tapes.
  • 2 more comments
  • Anonymous Jun 19, 2008
    My problem is similar. A DVD will play for several minutes, and then the image will freeze, then skip, then freeze, and finally remain frozen until it goes to "bad disk" and then shuts down. A video tape will also play for several minutes, and then the image degrades - the screen is covered with small trembling white diagonal lines. Is there any possibility this would relate to the cable connection between the DV2150 and the TV? The cable connection is the only thing that's been substituted.
  • fargrit23 Jun 28, 2008
    I have the same Go Video and the same "BAD DISC" problem. Thought it was the disc then tried another. Same thing. Thought it must be dirty so I tried a cleaning disk and it wouldn't even take it - it too was "BAD" (so sick of seeing that on the screen!) Tried playing a CD and it too was "BAD".
    Time to add to some e-waste? This was so easy to operate...
  • Anonymous Jul 25, 2008
    keeps on flashing bad disk, on every dvd, even when i put in a brand new dvd i just bought.
    flashes bad disk on all cds and dvds.
    i have tried cleaning the dvds and the cds, tried putting brand new disks in that i have just purchased and it still says "bad disk", even though the disks work in my computer.
I have the same problem with my Go Video DV2150 player. No disc in any format will play, the screen just reads Bad Disc. On my machine the DVD motor isn't spinning the discs.
The easiest way to find out if this is your problem to would be to place a disc noting the exact position any markings on it sit in relation to the tray before closing the tray. You can use a Sharpie pen or a small piece of tape to mark the disc too if desired or needed. After receiving the Bad Disk message eject the disc. Try it a couple of times. If the markings haven't moved you probably have the same problem I have.
Posted on Aug 03, 2008
  • 2,326 Answers
Try playing a CD instead of a DVD, if the audio CD plays normally that means that the laser on the DVD side is defective. This devices come with 2 laser picks, one for CD and the other one for DVDs.
Posted on Apr 04, 2008
I received a freebie DVD player but it won't play DVD it keeps saying no disc
The problem is in the laser pickup assembly, buy a DVD cleaning kit and follow instructions, it may help buy more time if not! replace the player not cost effective to repair.
Mar 24, 2012 | GoVideo DVD-VCR Combo
GoVideo DVD/VCR combo has a disc in it, and it plays, but I cannot ejecti it. I tried turn off machine and restart it but it still doesn't eject. It keeps reading the disc and plays the program.
there is a belt which is driven by a motor to open or close the tray. u place the disc on the try and the try loads the dvd/cd into the mechanism. the belt is loose & needs replacement. you have to open the cover & find the belt on the mechanism & replace with slightly shorter length of belt.
Sep 26, 2011 | GoVideo Go Video DVD/VCR Combo
My DVD player keeps saying "incorrect disc" when I
cd cleaner may help. lazers find it tough to read discs with dust on it.
Dec 30, 2010 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Samsung dvd vr330 combo keeps trying to load a blank dvd-r
HI Not fixed yet but reading some of the answers that appear to be very common I am going to try a dvd cleaner on the machine so hope it works
thanks for tue info
crawfordj939
Jan 31, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
The machine keeps stating bad disc, for all dvds. We have the GoVideo DVD VCR combo... we tried playing several different dvds and the machine keeps coming up with "bad disc".
It could just be dirt on the lazer/lens. Try cleaning it with a good brand name lens cleaner for DVD/CD. If that doesn't do the trick there might be damage to the lens, or an electrical fault.
Jan 04, 2010 | GoVideo Go Video DVD/VCR Combo
Zenith XBV243 CD player keeps ejecting disk
You may need to try a cleaning disc to remove dust from the laser heads, as dust may be impeding the player from recognizing the disc type.  Also, double check the manual to see what disc formats your player can handle.  All players have a variety of formats they accept or reject.  If the owner's manual verifies that it does accept that CD format, try the cleaning.  If that doesn't work, it may an issue that will require an authorized service center to look at, which may not be work the cost as replacement DVD players are very inexpensive.  Avoid combo players such as the DVD/VCR combo, as when one quits performing, you either have to replace the entire unit or add a new single component for the bad one.  Hope this helps!
Dec 06, 2008 | Zenith XBV243 DVD Player/VCR
Dvd wont work again
I have a emerson DVD recoder and VCR combo. I have the right disk but it keeps giving me the message can't recod on this disk. I can't figure out what to do? Can anyone give me any suggestions please.
May 20, 2008 | Emerson EWD2202 DVD Player/VCR
Bad disc message
Did you try cleaning the eye i have had dvds that would not play because the eye was dirty
Mar 10, 2008 | GoVideo Go Video DVD/VCR Combo
Free download user manual
i have Philips Magnavox MWD 200G model dvd player purchased in usa and put to use in India.it was rep[aired due to high voltage.later it is showing disc error for any cd or dvd whilke playing and indicvates that the play back feature nay not be available on this disc.but it plays Fuji Film DVD R.please advise me how can i solve the issue for playing the other cds or dvds
Mar 10, 2008 | Philips Magnavox DVD/VCR Dual Player
GoVideo DV2150 DVD Player/VCR Logo
150 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
