Question about Ricoh Aficio 3025 All-In-One Laser Printer
Does not print from Mac OX 10.5 Leopard
On installing networked RICOH Aficio 3025 and trying to print test page, printer makes a noise like it's starting to print for about 5 seconds and then stops. No error messages, print job disappears.
  • Anonymous Jun 12, 2008
    I have a similar problem. I add the printer via IP and it recognizes it with the correct name and everything, seems to be using the correct driver, but it doesn't show the correct icon in the print menu and when the print queue opens, the default is "printer paused." I try to resume the print and it just freezes again.
  • Anonymous Dec 14, 2008
    I have a similar problem except the printer print around 30 blank pages then stops.
    New Friend:
  • 58 Answers
From a mac, you need to have a post script print option installed, the system only came with pcl
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
SOURCE:
How do i find my mac address for ricoh 3025
Under "user tools" hit printer, then print the config page, info is there. -Carl
Feb 18, 2015 | Ricoh Aficio 3025 All-In-One Laser Printer
Hi, we cannot print to the Ricoh Aficio 2022. I have connected to the printer by pinging the IP address of it and it is OK. The 2022 can still photocopy. I have tried a test page and nothing prints.
Are you sure no other device on your network has the same IP address? (Turn the copier off and trying pinging that IP address to make sure.)
Do you have the Ricoh 2022 driver installed? You can download it from Ricoh-USA.com if you don't have it.
Aug 23, 2010 | Ricoh Aficio 2022 Black and White Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Can't print color or use finisher on our network ricoh from Mac
Sounds like you may not have the correct driver installed and also not configured right for devices
Dec 29, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Need driver for Apple Snow Leopard with spc210
Ricoh directs all users to Apple to review this link (below)to determine if their Ricoh printer meets Snow Leopard compatibility.
Ricoh Printers Supported for Mac OS X v10.6
If you find that your printer is on the supported list,
then you can download the driver software for Snow Leopard on the Apple Support site.
Here is the Apple Support Link:
Ricoh Printer Drivers for Mac OS X v10.6
If you do not find your printer is supported, then unfortunately this driver download will not work for your printer in Mac OS X Snow Leopard.
Regards,
-Mactechtrainer
Sep 28, 2009 | Ricoh Aficio SPC210SF All-In-One Laser...
Ricoh Adicio on a mac
Your machine requires the Postscript option installed in order to print from your Mac. The printer is printing gibberish because it cannot understand the postscript driver from the Mac. .
Jul 22, 2009 | Ricoh Aficio 2027 All-In-One Laser Printer
Mac OSX 10.4.11 won't print to Ricoh Aficio CL2000n network printer
Okay, this is what worked for me...
1) Remove the printer from your printers by going to System Preferences, then click on Print and Fax.  Highlight the printer and click the "minus" button below it to remove the printer.
2) Reset your printer by restoring it to factory settings.  On my printer, you would do that by turning off the printer, wait a few seconds, hold down the two buttons on top of the printer, turn on the printer, then continue holding the buttons until the red "Alert" light begins to flash.  Then let go.  The printer will reset itself and then start back up again.
3) Go back to System Preferences and hit the "plus" button to add the printer.  When the next windows opens, make sure the "Default" button is highlighted and wait about 15 seconds for your printer to show up.
4) Highlight the printer, DON'T CHANGE THE NAME IN THE TEXT BOX, make sure the proper "Print using" driver is selected, then click "Add."
5) That should add the printer as your default printer.  Just make sure you don't change the name of the printer either in Leopard or by going into your printer's configuration utility.  Everything needs to remain as default!
With this printer, I used to try to change the name of the printer when I was setting it up to something more familiar like "Network Color Laser Printer" or something like that, but after about two days of working, it would suddenly not work printing from my Mac anymore (although the Windows computers could print to it without a problem).  Now, after leaving everything with its default name, my Mac always connects to the printer.
Anyway, just try it out-- what have you got to lose?
Aug 29, 2008 | Ricoh Aficio CL2000N Laser Printer
Ricoh Aficio 3025 All-In-One Laser Printer Logo
343 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
