Question about Intel Celeron -D 2.26Ghz Computer System PC Desktop
Easynote R4 no screen visible and nothing from an external monitor either.
  • PiotrekP Nov 23, 2008
    I have got the same problem.
    My latpop started to have prblems with the graphics and could not start from thime to time. Finally it has given up and now it won't start.
    The lights -just the green stating that the computer is on.
    No response from the keyboard (CTR, Alt, Del)
    No external video when connected to the External Monitor.
    Please advice.
    Is that problems with motherboard or the processor, which I could exchange still.
    can it be fixed?
No beeps at all.
Just a green light for the power up.
There is some hard disk activity light at the beginning as well but there is no any response to the restarting key combination afterwards.
Also when the battery is installed there is a light blinking to show that the battery is not charging.
According to the Packard Bell Support I have removed the battery and powered up the laptop. Unfortunately the system doeas not start. However when I reinsert the battery it shows green light showing that the battery is charging. it last for five minutes ;-(
before the laptop gone dead the was a line accross the screen at the start up. Now the screen is completally dead. No external video when connected to the external monitor.
I think I start repeating myself.
Any advice? (beside buying the new laptop ;-) )
Posted on Nov 24, 2008
  • 1,019 Answers
graphics chip blown.
are you getting any lights flash at startup, or any beeps for the bios errors ?
Mike @ compurepair.
Posted on Apr 04, 2008
My Packrdbell easynote mz35 power up but nothing happens all the light (power, Battery and HD) are on (no blink) but nothing displays on the screen and I can hear hard disk spinning . I have try F8 to...
Does it have a connection for an external monitor? If it does, connect a different monitor and see if anything shows up. The fact that you are not hearing any beeps really sounds like either your display is fried or you have a serious motherboard issue. Anyone else have an idea? I hate to tell you this friend but that laptop does not get a high rating for reliability. New?
May 22, 2012 | Packard Bell Packardbell EasyNote...
I have a TJ68 packard bell Easynote laptop, it will power up, but display screen is black and flickers. I connect a vga cable to an external monitor and can see contents of laptop on external monitor.
The fact that you can see the desktop on the external monitor means your LCD Inverter on the laptop is bad. The video card in the laptop is good, otherwise you would not be able to see the desktop on either screen.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
The lcd inverter can be purchased on ebay for less than $15. It is located at the bottom of the lcd screen. You'll have to remove the plastic strip that is around the lcd screen by removing the plastic or rubber bumpers that have screws under them. Normally there will be bumpers at each corner and maybe along the insides on the plastic strip. Remove the bumpers, the screws and pry the plastic strip off with a little force with your fingers. You will then see the lcd inverter at the bottom of the lcd screen.
Just put your computer's name and model in the ebay search followed by lcd inverter.
Actually it looks like your laptop uses the LED screen instead of LCD so it will not have the LCD Inverter. You will have to purchase a new screen. I found the one below on ebay.
May 13, 2012 | Packard Bell Computers & Internet
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
HP Mini-1101 Atom 1.6GHz 10.1in 2GB 160GB Laptop.Its screen has turned green.Nothing visible. where could be the problem. Thanks
The problem could be with the monitor or the mother board. I would suggest you to take it to the Authorized Service Center.
Just to confirm, I would also suggest you to get the display connected to an external monitor. This could help you to confirm, whether the problem is with the monitor or the mother board. To do this
Connect a external monitor by fixing the wires to the display out and toggling the display from the laptop to the external monitor by pressing Fn + F5
Mar 11, 2010 | Computers & Internet
White screen on lcd nothing visible but output ok
i think you should try Fn-F5 not F6 hold the button down a while
Dec 21, 2009 | ASUS Eee 4G Notebook
My lenovo Y510 ideapad turns on but the screen remains black. All of the buttons light up, but the screen stays like it is in sleep mode. I have tried rebooting, removing the battery but nothing seems to...
The next tim eit is turned on, try shiniing a bright flashlight directly on the screen.
If you can see anything there then the backlight has burned out on the screen, and will need to be replaced.
If you cant see anything, try hooking up an external monitor to the laptop, if you have a desktop the monitor for it will work for the test..
If the external monitor you hook up will work, then you will have to replace the screen..
( or at a minimum the inverter board, or check that the cables are tight that go to the screen)
Oct 31, 2009 | Lenovo IdeaPad Y510 Notebook
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
Sep 06, 2009 | HP Pavilion dv6000z Notebook
Laptop screen has vertical black and white stripes
when you hook up the external monitor did you hit the fn key and f5 this should turn on the external monitor port
Apr 12, 2009 | Dell Vostro 1000 Notebook
Packard Bell R9252 Easynote laptop screen has pink shadow ??
Easy to obtain - yes. No so easy to replace. First connect an external monitor to your laptop. This will insure that the electronics is all right. If that's alright then go to to order a screen. Make sure you order the regulator with it. The price for this package may make you think otherwise about replacing it.
Mar 27, 2009 | Computers & Internet
Don't know what to do !
connect external monitor to see if adapter is ok. If external monitor comes on OK,(check to see if the FN+F5 or another key has to be toggled for external display) then shine flashlight on screen to see if Icons are visible. If the Icons are visible LCD inverter would have to be replaced. If external monitor works and Icons are not visible lcd is probably no good, If external monitor does not work then Video adapter is bad.
Apr 05, 2008 | Compaq Armada 1750 Notebook
Open Questions:
as some sites suggest about cheat for igi game i tried it and make changes under Project IGI- I'm going in Cheats----hi friends in this game it is difficult to get the blood/medipack to get this use the folowing instruction. 1)first go to the igi installed folder then go to weapon folder u will find some folders like Ak47,binoculars,colt anaconda,medipack etc. 2)then go to Ak47 folder you will find a folder like weapon the open in hex editor u will find a string like weapon_id_Ak47 by using hexeditor edit the string to weapon_id _medipack. then similarly go to medipack folder u will get a folder like weapon then open in hex editor edit weapon_id_medipack to weapon_id Ak47 the save it. 3)when u will kill a soldier u will get a medipack. for hex editing i installed software and changes in hex file as i described above but due to mistake my igi game not start well aND , SHOW A error like igi stopped and shows problem detail Problem Event Name: APPCRASH Application Name: IGI.exe Application Version: Application Timestamp: 3a1d74c6 Fault Module Name: StackHash_169c Fault Module Version: Fault Module Timestamp: 00000000 Exception Code: c0000005 Exception Offset: 00000000 OS Version: 6.1.7600. Locale ID: 1033 Additional Information 1: 169c Additional Information 2: 169c69b50cca39ebafad90cf9acfe712 Additional Information 3: 166e Additional Information 4: 166ed9faa1184e606930c56f1ef84d85 please send solution ... or reply
Dec 31, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Intel Celeron -D 2.26Ghz Computer System PC Desktop Logo
225 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
