hey and thanks for your time...i tried to push up on it and it still wouldn't catch the thread...so i tried it again with a little harder...only thing is it came off in my hand...i don't know how to put it back on...it doesn't look to be broken...please help...red
Remove the needle and place it back in, the needle may have just slipped down out of place a little. Another thing to watch for is the foot that comes down to thread the needle may no longer be straight you might need to slowly push down the cartridge and watch to see if it tilts down to the left if it does you can carefully place your finger under the part that holds the thread and slightly lift it till its straight and continue to thread the needle. I have had that problem and just bent it back up carefully and no longer have that problem.
Hope that helps
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on threading with the auto cartridge:
Solution #2
posted on Apr 16, 2008
Guest
Rank: Apprentice Rating: 0%, 0 votes
make sure that the thread is snug...do you have the thread cap on? I've had this problem and it is usually corrected if the thread doesn't have any play inside of the cassette.
Rating Locked! (?) nonibear has rated this solution as Helpful
Thank You!
Was the solution helpful?
