Question about Garmin Forerunner 305 GPS Receiver
The screen has just gone gray and will not turn on or off
  • 6 Answers
To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
Posted on Apr 29, 2008
SOURCE:
LIGHT GONE IN SCREEN
With the unit turned on, turn off the lights and with a flash light shinning at the LCD screen, do you see any images ?
If so, the Back lights or inverter have gone south.
That is a cheap 17" unit and would not be worth the repair cost.
Jan 25, 2014 | Sharp LL T17A3-H (Gray) 17" LCD Monitor
I can not join a game with a friend. Others can join but we can not. Y
one thing you guys can both do is turn off your system then turn off your router for 30 seconds; turn router back on then turn ps3 back on and try reconnecting with each other. if this doesnt work make sure both of you have open NAT types. Hope it helps.
Oct 07, 2012 | Ubi Soft Entertainment RUSE for...
Top portion of screen has black and horizontal/vertical white lines. When I turn it on screen is dark gray and unreadable. When pushed to turn pages, lights up briefly, then goes dark gray again. Worked...
Try to hold the slide key for 15 sec. It will reboot your kindle. If black patch is not gone even after that, It's a hw issue. Screen might require to be changed. If it's in warranty Amazon will do it free. That's what i have heard.
Mar 01, 2011 | Amazon Kindle Wireless Reading Device
Last the picture . have a white or gray screen. It was working fine one minute then the picture was gone. It's not the PC ,I check.
Gray glowing screen can be due to bad T-CON board (blown fuse, bad IC), or the main baord is not sending the 12vdc to the T-CON board. See my giudes.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 23, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Gray bars
Hi, you can removed this bar by using the picture size function in you menu this is du to the signal
you receive in your tv;if your tv got a full hd signal
choose the 16:9 picture format the bar will disapear
if you dont have 16:9 signal that normal but you can choose full screen mode it should gone , that is 4:3
format extend it to ful screen mode.
good luck and have a nice day.
Mar 13, 2010 | Televison & Video
Blank screen,computor running but no picture on screen only gray colour.
Do you get a POST bleep when you switch on?
If so it could be a cable fault or a graphics card fault, either the driver has corrupted or the card itself has gone faulty.
Oct 17, 2009 | Computers & Internet
Screen displays gray shadow initially
hi,
there is nothing like that,might be the issue is with the display cable only and if it is then it is not very costly but if screen gone bad then it is better to go for new on so please get it checked by a nearby expert.
Thank You.
May 29, 2009 | Sony VAIO VGN-FE550G Notebook
Gray bands on recorded tape
The drum is dirty purchase a soft cleaning tape that should do it
Dec 23, 2007 | Sony Handycam DCR-PC115E Mini DV Digital...
Garmin Forerunner 305 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
