Question about Motorola Mobility RAZR V3
Charging the Razor
I have a V3 Razor. I know there are different settings for how long you should allow your phone to charge. I have heard the shorter the amount it charges the worse your battery can get. What do you suggest for how many hours I should set it for?
    Problem Solver:
  • 21 Answers
I would set it for the max timebecuae, when you charge it for shorter times it ruins the battery faster.
Posted on Apr 05, 2008
SOURCE:
Razor Phone wouldn't charge...battery dead, so I replace with new battery. It still will not indicate that battery is charging. I tried several outlets to plug in charger. Still no charging. Phone...
Sounds like you may have a connection problem where the charging cable plugs into the phone. Not much can be done except to get a new phone. Those micro USB/USB style connections last a long time, but once a pin is bent up it is game over. Sorry!
Mar 03, 2011 | Motorola Mobility RAZR V3
My motorola razor says unable to charge bought new battery cleaned out phone nothing works
in the settings menu,there is a place that has a charge time adjust.Turn it off so the charger will start charging the battery.This is a feature so you can set the phone to charge in minutes,if the bat is too dead,then it would need hrs charging.Thats why it cannot start.
Apr 02, 2010 | Motorola Mobility RAZR V3
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Oct 26, 2009 | Motorola Mobility RAZR V3
Overheating of razor phone
the v3 is known for battery issues. not charging, not holding charge and overheating. my suggesting is get a different model phone. and stay away from razors. they all have battery issues, I know this from multiple customer razor issues. all battery issues.
Jul 22, 2009 | Motorola Mobility RAZR V3
Razor will not charge
my own razor does this also. the problem is the charging port on the phone. try using an electronics cleaner inside the port but do not oervsaturate. Otherwise if the phone is warrantied or you have insurance take your phone in and get it changed. I had a spare phone that i use to charge my battery. hope this helps.
Sep 11, 2008 | Motorola Mobility RAZR V3
My razor v3m battery
display brigthness is a factor along with blue tooth try fully charging the battery for a long time
Jun 21, 2008 | Motorola Mobility RAZR V3
RAZOR V3 wont charge
clean the charging port, try changing the battery if that does not work then take the phone and have it checked.
Jun 19, 2008 | Motorola Mobility RAZR V3
V3 unable to charge
reflash the firmware this will correct the charging issues and if that does not fix it then have the mainboard replaced.
Feb 17, 2008 | Cell Phones
Charging?
Your battery may have a low voltage, you need to rejuvenat is unfortunatly you cant do that if you dont have tools to do it, but that will be your problem (Battery)
Jan 10, 2007 | Motorola Mobility RAZR V3
Motorola razor v3 display problem
If the charger is not an original motorola charger,, then you have a problem. make sure its original.
Oct 11, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
