I just loaded my WM and it's full of water but, it won't turn.
    President:
  • 778 Answers
Make sure your machines timer is set to the proper position on the cycle you want and close the lid. Also make sure that the power cord is plugged into a working outlet.
Posted on Apr 04, 2008
SOURCE:
Water turned off unexpectedly now machine won't spin final cycle and timer stays on 4 min and appears to continually try and drain ( intello 7.5
Unplug unit for 5 minutes to reset control board. If problem still persists, you will need to call a technician to service it.
Jun 15, 2011 | LG WM-2277HW Front Load Washer
How do i access my dryer filter
On the front at the bottom left is a rectangular panel that you pop off. (I use 1/2 a wooden laundry clip so as not to scratch finish.) Have a bowl or a bucket handy and perhaps a towel or two. There is a tube clipped to the washer. Detach from washer and unplug it and let water drain into your bowl. When water stops flowing, plug and reattach. Then (with towels ready) turn the the pump filter counter-clockwise (the circle to the right of the tube) until it comes out. More water will drain in this process. Clean the filter of any foreign objects. Replace and turn clockwise until it won't turn any more.
Apr 17, 2011 | LG WM-3677HW Front Load Washer / Dryer
WONT TURN OR SPIN, BUT WATER FILLS AND DRAINS OK
Can be more solutions to this problem:
First check if installation was correct, 4 screws needs to be unscrewed from the back of your WM, they are intended to keep the motor safe when transport your product.
Second, depends on the model some WM are equipped with a sensor for balancing the drum. It wont go to spin till the loading is not properly untangled. You have to load more or less cloths according to WM specifications.
Apr 12, 2011 | Washing Machines
I'm getting an error code EU. It shut off and was full of water.
Hello, the EU error means "Unbalanced load" is sensed three times during a spin operation, and to resolve the issue.
1. Open lid and Re balance laundry load and close lid.
2. Check wiring harness
3. Check unbalance switch
4. Check circuit board
Thanks
Jun 10, 2010 | LG WM-2277HW Front Load Washer
Soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
May 09, 2010 | LG WM-2277HW Front Load Washer
Keeps flashing LE full of water will not spin water out or anything.
Hee is a tip that will help you check out some things that could cause that code...remember also that the sensor can go bad...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 14, 2010 | LG WM-2277HW Front Load Washer
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
Water level for a front load LG washer?
You're not silly. You could hv said which country you are from..... The water level is usually low, except when the rinsing takes place, when it comes to about half at the glass window. Make sure you turn on the faucet on the wall full when you operate the machine; you can close faucet after wash. (dont forget to open when u begin next wash!!)
Jan 09, 2008 | LG WM-1832C Front Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
